Mesh requirements for k-w models
Like Tree4Likes
  • 4 Post By cfd seeker
Old   October 19, 2012, 16:27
Default Mesh requirements for k-w models
Jeremie84 is on a distinguished road
I am wondering if it is relevant to use the k-w models (standard or SST) with coarse mesh near the wall (y+>50). I read that in the Fluent User's guide and I am a little confused:
"Both k-w models available in ANSYS FLUENT are available as low-Reynolds-number models as well as high-Reynolds-number models. Therefore, the mesh guidance should be the same as for the enhanced wall treatment."
Also, what the advantage of using the "Low-Re corrections" option for the k-w models? Is it relevant only for fine meshes (y+<5)?
Thank you
Jérémie
Jeremie84 is offline   Reply With Quote
Old   October 19, 2012, 16:40
Ehsan Asgari
syavash is on a distinguished road
Thank you
Jérémie
If you have a High Reynolds problem, you may implement k-w with y+ between 30 and 300. If your problem regards low Reynolds, then you can check "Transitional flow" option to take into account low Reynolds correction. in this case y+ should be in order of 1.0.
Good luck
syavash is offline   Reply With Quote
Old   October 19, 2012, 17:14
Thank you Syavash for your answer.
I know that there is not an universal rule, but is there a typical value of Re from which we can consider a high-Re problem?
I am studying a VAWT, and I have a range of Re from 100 000 to 500 000.
Thanks again
Jérémie
Old   October 19, 2012, 21:17
Ehsan Asgari
Thanks again
Jérémie
Actually I'm not sure, I think we should consider transitional length in which flow turns into turbulence. If that would be substantial length in comparison with the characteristic length, we may assume it to be low Reynolds regime.
But I would rather prefer to compare the numerical results with experimental ones to make sure which model I should choose.
Old   October 20, 2012, 04:31
cfd seeker is on a distinguished road
Thank you
Jérémie
Standard and SST versions of kw model by default use Enhanced Wall Treatment(B.L is resolved all the way upto viscous sublayer) and therefore wall y+<5 are generally recommended but theses models have the flexibility to switch over to Wall functions approach once a course mesh(wall y+ > 30) is used. So you can use it either way.
But if your sure that in your case transition is taking place then don't use "Low Re. No" option because in Fluent 13 they themselves have mentioned that "Low Re. No" does not perform good in such a situation. In Fluent 12 onward they have incorporated two new Turbulence models to properly capture Transition phenomenon, these models are Transition k-kl-w(3 eq. model) and Transition SST kw(4 eq. model). But again these models give you an extra headache because of their stringent mesh requirements i.e
1. Wall y+ <1
2. Sufficient Mesh resolution in streamwise direction
3. Proper estimate of Turbulence Intensity at the Inlet boundaries
Regards
cfd seeker is offline   Reply With Quote
Old   June 13, 2014, 10:49
Jonathan is on a distinguished road
Hi Seeker,
I am looking at using the Transition SST model to predict transition on a turbine endwall and aerofoil.
I was wondering whether you knew whether it is a good idea to use the Low Re Correction's (i.e. Wilcox's damping functions) as well as the additional equations for transistion, or whether one should leave out the Low Re Corrections when using the additional transition equations.
I havent read anywhere that you shouldn't, but when i did, i didn't quite get intermittancy levels of '1' where i thought i would - i got a max of ~0.5 where i thought the BL should have been fully turbulent!
Any comments or thought based on your experience???
thanks very much
cheers
jonathan
1. Wall y+ <1
Regards
Jonathan is offline   Reply With Quote
near wall mesh, turbulence model
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 06:25
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
