Unknown walls generated when import .msh file to fluent. |
October 12, 2012, 06:34 |
Bryan
hello, guys.
I have a problem and need a help. I made geometry like the picture, generated mesh and tried to calculate with fluent. but the flow was interrupted by some walls. I didn't make walls. (picture attached) but fluent made some walls when the .msh file was imported. I want to delete the walls or make them like interior. how can I solve this problem? please save me... |
October 12, 2012, 08:37 |
Gonzalo
Rep Power: 16 |
HI:
Make sure you had created all the Named Selections in Ansys Meshing that you need to declare, and when you inport the mesh into FLUENT, look at the list of mesh parts and display them. If some of the interior faces of the ducts have a wall BC's, chage it as interior faces, but by default FLUENT must import them as interior faces as well Gonzalo Last edited by gfoam; October 12, 2012 at 09:33. |
October 15, 2012, 20:59 |
Bryan
Hi, Gonzalo.
I made named selections all over the body parts. And walls didn't be generated inside when I import the mesh into fluent. But the problem was not cleared. Flows still couldn't go out. Then I focused on connections. Geometry and mesh model was comprised with many parts and contact regions were generated automatically to connect between parts. Then I made contact regions manually and the problem was solved. I can make contact regions easily because of the named selections. If I didn't make named selections clearly, I cannot try to make contact regions manually because the model has so many parts and faces. I'm so grateful for your advice. Thank you. Bryan. |
October 16, 2012, 03:50 |
Flavio
Rep Power: 16 |
Hi mdw,
you can also put all the body pieces in one part (if you are using Workbench it's quite simple) in order to avoid the connections and have a conformal mesh Regards
Bionico |
October 16, 2012, 14:32 |
#5 | |
Gonzalo
Rep Power: 16 |
Gonzalo |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 12:44 |
.msh file cann't be by Fluent | nchuche | FLUENT | 1 | June 29, 2010 11:38 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
