WSS and normal velocity gradient for the slanted pipe
Like Tree1Likes
  • 1 Post By wanna88
Old   September 26, 2012, 07:38
Default WSS and normal velocity gradient for the slanted pipe
Naimah
wanna88 is on a distinguished road
Hi all,
I have question regarding the wall shears stress and the velocity gradient in the slanted pipe
Based on Fluent user guide:
In a laminar flow , the wall shear stress is defined by the normal velocity gradient at the wall
There will be no problem to calculate the normal velocity gradient for the case in the straight pipe. For example the axial flow is in z direction, the velocity gradient can be calculated by find the difference of the adjacent z velocity to the 0 velocity at the wall then divide by the distance from the adjacent z velocity to wall.
How about in the slanted pipe when there is flow in the y and z direction? Which velocity need to be taken to calculate for the velocity gradient? attached figure
I have this problem since my geometry is an irregular shape. It have difference direction of the velocity.
I need to verify why I have the high WSS at certain region. The only way is by using the velocity gradient. But in this case, Im not sure which velocity should be taken.
Hope someone can help me.
Thank you so much.
Regards,
Naimah
skyblue_mech likes this.
wanna88 is offline   Reply With Quote
Old   September 26, 2012, 16:00
Debanjan Deep
skyblue_mech is on a distinguished road
Hi ,
I am having the same problem for calculating the WSS for complicated boundary shapes. Did you get the answer ?
Please let me know if u did.
Thanks,
Debanjan
skyblue_mech is offline   Reply With Quote
Old   October 1, 2012, 23:34
Naimah
Do you find any answer for this?
I found out that there are different ways to calculate the WSS for 2D and 3D case.
http://www.cfd-online.com/Forums/main/11103-calculate-y-u-how-get-wall-shear-stress.html
Wall shear stress = u_tau = sqrt{ tau_wall / rho }.
For a 2-D flat plate flow, you can assume tau_wall = tau_xy = mu du/dy_wall.
For a 3-D flow, you need to compute tau_wall from the stress-strain tensor (tau). You can do this by:
tau_wall = sqrt{ Rx^2 + Ry^2 + Rz^2 },
where
Rx = tau_xx * nx + tau_xy * ny + tau_xz * nz and so on...
Here, {nx; ny; nz} is the face normal direction attached to the wall.
But, Im not really understand the above explanation
I found out in 1 paper
wall shear stress = 2*miu*(strain rate tensor.normal vector on the wall)
Strain rate tensor + 1/2 (dui/dxj + duj/dxi)
Can you help me to take a look also on this?
Thank you.
Regards,
Naimah
