September 20, 2012, 02:26 |
Considering Humidity in the Air
M
Rep Power: 14 |
Hi Guys,
I am modelling a building block ( a room ) with Air inside for Natural Convection. I wonder If anyone knows how can I consider the impcat of Air humidity in the model? Cheers, |
September 20, 2012, 02:39 |
Philipp
Rep Power: 27 |
You need to find a database, that contains all relevant physical properties of air as a function of humidity. Then, you can put these values into fluent (Materials->Fluid->Air->....). You will need viskosity, specific heat capacity, density, thermal conductivity and whatever your model needs. |
September 20, 2012, 21:05 |
Ehsan Asgari
Rep Power: 18 |
I think you should use Species to model the humidity in the air. Knowing mass fraction of water-vapor at room and solving set of N-S equations plus an additional equation for water-vapor.
Goodluck |
May 29, 2013, 17:17 |
Rep Power: 13 |
hi ariya, i'd like to know what have you done with your work? did you find how to simulate it?? i'm simulating thins kind ,i was wondering if you could show me please thx
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
how to set the relative humidity of air in DPM | saturn | FLUENT | 0 | April 17, 2009 06:17 |
Air humidity modelling | Chaz | FLUENT | 5 | October 16, 2003 05:10 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
Air with humidity | Dan Sorensen | Siemens | 0 | February 10, 2000 09:53 |
