Mass Imbalance in Reaction Stoichiometry in FLUENT
Like Tree2Likes
  • 2 Post By epc1
Old   September 1, 2012, 20:33
Default Mass Imbalance in Reaction Stoichiometry in FLUENT
Jenny
Jenny_W is on a distinguished road
Dear All
I'm simulating a simple chemical reaction HCl + NaOH ==> NaCl + H2O.
I create reaction mechanism files in CHEMKIN format and import them into FLUENT. However FLUENT shows "warning: mass imbalance in reaction-1 stoichiometry" and I am confused since the reaction is already balance.
Another problem is that along the centreline of my domain, the concentration of NaOH increases beyond the original concentration at the inlet. This is not realistic. The NaOH concentration should be lower than the concentration at the inlet because some of NaOH has been converted to the products.
I do not know what the problem is. If anyone has any idea or suggestion please kindly advise.
Thank you,
Jenny
Jenny_W is offline   Reply With Quote
Old   September 16, 2012, 23:23
Red face Same problem...
sir
sirly
sir is on a distinguished road
Hi Jenny..
I also got the same warning..I already check the stoichiometry; and it is balance..If you hv any idea, hope u don't mind to share...and i will struggle to find out the solution..
C u
sirly
sir is offline   Reply With Quote
Old   September 17, 2012, 06:54
Jenny
Hi Sirly,
I'm sorry I still cannot find the solution to this. If I can solve the problem, I will let you know
Jenny
Old   September 17, 2012, 12:57
Ernesto
epc1 is on a distinguished road
Hello, i´ve had this problem sometimes in the past.
I´d recommend to check the Molecular wieghts of the species involved in the reactions, in the materials panel.
Jenny_Wong and jumaah like this.
epc1 is offline   Reply With Quote
Old   September 18, 2012, 12:01
Jenny
Jenny_Wong is on a distinguished road
I'll do that. Thank you very much Ernesto.
Jenny_Wong is offline   Reply With Quote
Old   October 28, 2013, 08:32
Daniel Sebastiŕ Sáez
danielet82 is on a distinguished road
Hello, I experienced the same problem and I couldn't initialize the domain and run the simulation. I checked the molecular weights of the species involved in the reaction and it can be initialized and it gives good convergence despite the fact that the same message appears.
danielet82 is offline   Reply With Quote
chemical mechanism, chemical reaction, chemkin, combustion, mass balance
fluent definitions for mass fractions perdita FLUENT 0 December 6, 2010 06:00
FLUENT Conservative with respect to Mass mannobot FLUENT 1 October 18, 2010 15:17
Converting experimental mass flows into 2D fluent Trond G. Grüner FLUENT 3 April 12, 2005 09:22
Mass imbalance Aly FLUENT 7 October 6, 2004 22:07
Residual Problem -Mass Imbalance Jie FLUENT 0 February 19, 2002 11:49
