Rep Power: 14 ![]() |
Hi dear friends
l have an important problem about fluent in modeling a spillway.in results i see negative pressure which is not correct.as a matter of fact,pressure must be positive.on slope,pressure must begin with positive mesure and change along the spillwau.but in my results ,pressure begins with negative mesure.i don't know what the problem is! |
Guiliguili
Rep Power: 16 ![]() |
When you select Pressure, select also Absolute pressure instead of Static Pressure which is chosen by default
Thanks
I try that.but it doesn't work.pressure is still negative.the velocity measures are correct.do you think modeling in gambit is wrong?or is there any special setting in fluent which is effective? Thank you very much |
Guiliguili
I don't think it's about the mesh. How did you set your boundary conditions specially for pressure and your Operating Conditions?
For example:in a simple model consist of a simple slope,i use :
Velocity inlet as input pressure out let as output Symetry Wall. |
Operating pressure is 101325
And also i apply variable density parameter 1.225 |
To know the reason, you may check these in sequence.
-pressure outlet is the same as you set. -pressure drop between inlet and outlet is reasonable. if this result is available, you then check your simplification model. Maybe there some different between the real model and the simulation model |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Submerged fin, Convergence problem | supermouniette | FLUENT | 10 | July 6, 2009 10:47 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
