how to give swirl flow in 3D cylinder by using fluent 6.3
Like Tree2Likes
  • 2 Post By LuckyTran
Old   June 3, 2012, 08:12
Default how to give swirl flow in 3D cylinder by using fluent 6.3
shivammaurya
shivampm is on a distinguished road
hi
i am trying to give swirl flow of different swirl no. like 0.4,0.8,1.4,2.7 etc using fluent 6.3. In 3d cylinder body how can i give swirl flow. suggest me procedure please....
thanks in advance
shivampm is offline   Reply With Quote
Old   June 3, 2012, 14:13
Lucky
Originally Posted by shivampm View Post
hi
thanks in advance
what is the flow domain? your description is inadequate.
you can specify any number of velocities, wall shear stresses, or applying moving walls to get swirl flows. it is rather straight forward. there is nothing special about swirl, it is just velocity in a different direction and you just proceed with that in mind. If you are trying to apply swirl to a plane inlet velocity, then it is a little more difficult.
Old   June 3, 2012, 16:09
shivammaurya
thank you for your suggestion.Flow domain is as mention in the diagram ( fig 1).
I want to give swirl velocity with axial velocity from inlet face as shown in diagram...
wts procedure for it???????
Old   June 3, 2012, 20:54
Lucky
You can apply "swirl" through the velocity inlet boundary condition settings
Choose components as your velocity specification method, and use a local cylindrical coordinate system
specify your cylindrical coordinate system and then specify the angular velocity to get the swirl number you are looking for. Obviously this method only works for constant swirl. If you want varying swirl number you need to do more work.
utkunun and HHK like this.
Old   January 28, 2019, 05:52
Chris1590000 is on a distinguished road
Hii, Could you please elaborate on this.
I want to model a swirl diffuser in a room, therefore I need to add a constant swirling effect on the flat side of the cylindrical diffuser on the ceiling, so that the air can distribute in a swirling flow to the room.
I chose a velocity inlet BC at the inlet where the swirl has to be created, Please tell me what inputs I need to input to get the desired swirling effect for the diffuser.
Thankyou.
Chris1590000 is offline   Reply With Quote
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 06:56
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 02:22
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
BCs in Fluent for flow inside a cylinder. MikeTichondrius FLUENT 0 July 13, 2011 10:57
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
