May 30, 2012, 05:34 |
Coal gasification: reactions not working
rabbahs
Rep Power: 16 |
Dear all, First of all thanks for reading the thread, I really appreciate it. I am trying to model coal gasification process in fluent using the species transport. The step that I follow to perform the analysis are given below. The parameters that are not mentioned are taken by default. I am only performing this exercise to see the potential of species transport for the coal gasification, but at the end of the day the simulation was not working ... yyyyyyyyyyyyyyyyyy ... I don’t have any clue Anyway, the steps are given below, 1) Import the mesh file in Ansys Fluent 12.1.4. The geometry is a 2D rectangle (10m by 1m), have a nozzle in the center and an end face as outlet. (fairly simple geometry) 2) Define>model>energy equation> ON 3) Define>model>viscous model>K-epsilon 4)define>model>species model>species transport. 5) under species transport, the volumetric and particle surface reaction are unabled. 6) similary, finate rate/eddy dissipation model is selected. 7) species mode> coal calculator> default values selected that generate a mixture material “coal-volatiles air”. 8) now in the material panel: material are selected and edited for mixture so that it contain “vol, o2, h2, co and n2” in the fluid speices and “C<s>” in the solid species. 9) now the two reaction are defined as, a) volumetric reaction vol + 0.885 o2 = 1.898 co + 2.381 h2 + 0.017 n2 b) particle surface c<s> + 0.5 o2 = co2 10) define injection >new Injection type>surface> “NOZZLE surface” b) Particle type>combusting c) Custom law> ticked d) Temp>450, velocity>5 m/s, flow rate>0.1 kg/s 11) Material>combusting particle>combustion model> “multiple surface reaction” is selected. 12) Define>boundary condition>nozzle (velocity inlet)> velocity =10 m/s, species > o2 mole fraction =0.21, temperature=450 13) Initialized and run for couple of thousand iterations. The only check I have that I check the temperature contours. Because if reactions are working than the temperature should go up. Remember, the temperature I am putting for air inlet and injecting particle are above the devolatalization temperature. But I never get any reaction happening and maximum temperature remain the same as inlet conditions Any comments and suggestions are welcome. At this point I can try anything because the grid is fairly small so it will not take any time. If anything is unclear then just shoot a question. Thanks |
May 30, 2012, 08:14 |
Theodoros Papadopoulos
Rep Power: 15 |
when you tick the custom law option did you check which laws are enabled?
May 30, 2012, 08:37 |
rabbahs
Rep Power: 16 |
Hi Papeto,
thanks for the reply. Please view the image below. Untitled.jpg but surprisingly when I open the injection panel, the custom law check box was automatically unchecked. thanks |
May 30, 2012, 08:42 |
Rep Power: 15 |
why you are not using the default values for the laws?? if you enable the combustion particles' injection then the laws are automatically imported and you don't have to select them. But I can no tell you more if I don't have a look at your case...
May 30, 2012, 08:47 |
rabbahs
Rep Power: 16 |
give me your email address I will send u the case and data file
thanks buddy |
May 30, 2012, 10:10 |
Rep Power: 15 |
May 30, 2012, 16:16 |
rabbahs
Rep Power: 16 |
email sent
April 27, 2013, 03:08 |
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
Rep Power: 16 |
January 7, 2014, 15:02 |
#9 |
Sebastian
Rep Power: 14 |
Good afternoon, I'm experiencing the same problem, when I open the injection panel, the custom law check box is automatically unchecked, I have a complex gasification kinetics, but the reaction rates seems to be lower than expected. I would appreciate your help, thank you.
May 29, 2017, 05:10 |
Please also send me case and data file of coal gasifer
#10 |
BILAL HUSSAIN
Rep Power: 9 |
coal gasificaton, finite/eddy, species transport |
Coal gasification fluent | arnab | FLUENT | 9 | July 20, 2019 08:42 |
Nonpremixed Combustion Model for Coal Gasification | C.Y.Ler | FLUENT | 2 | April 29, 2014 08:51 |
Coal gasification | DYANA | FLUENT | 20 | April 17, 2013 10:19 |
COal GAsification: defining Coal | coalgas | FLUENT | 0 | May 1, 2009 01:10 |
Coal Gasification | Macy | FLUENT | 1 | September 24, 2007 13:48 |
