May 5, 2012, 11:00 |
free stream temperature
Vaibhav Rai Khare
Rep Power: 15 |
What does Free stream temperature and external radiation temperature meant in boundary condition--> Thermal.
May 5, 2012, 15:30 |
#2 | |
Lucky
Rep Power: 66 |
It should be self explanatory if you know anything about heat transfer. Did you even bother to read the Fluent help file? If you don't know those quantities perhaps you shouldn't be using Fluent? |
May 15, 2012, 04:03 |
Vaibhav Rai Khare
Rep Power: 15 |
@LuckyTran: Ohhkkk.. That means you should have read the whole FLUENT user manual. So tell me the equation to calculate the external radiation temperature and how can we define the value of both???
And for your knowledge i would like to tell you that the free stream temp and external radiation temperature don't have any physical significance in Heat transfer..Both are defined by FLUENT itself.. |
May 15, 2012, 11:41 |
#4 | |
Lucky
Rep Power: 66 |
And for your knowledge, I would like to tell you that, for both conduction and convection, without a free-stream temperature there is no heat transfer as there is no heat. Therefore, the free-stream temperature and external radiation temperature both have a physical significance in Heat Transfer and have a direct influence on it. Heat transfer occurs via conduction, convection, and radiation. Just because it doesn't play a direct or obvious role in radiation does not mean that it has no physical significance. I will now tell you the equation to calculate the freestream temperature and external radiation temperature as you requested. Here they are: ( ) there. They do not have any equations to them as they are just temperatures of specific configurations. |
May 15, 2012, 11:59 |
Lucky
Rep Power: 66 |
Because I am a nice guy I did spend time reading the Fluent help file just for you.
In section 7.3.13.3 Thermal Boundary Conditions at Walls (different sections occur in different versions of the manual, it is 7.3.14 in some versions but they do not differ by a whole lot) you will find the discussion on what each term means, Fluent mentions external radiation temperature here 7.3.13.11 Fluent explains that the external radiation temperature is the temperature of the radiation source or sink on the exterior of the domain, defined by you. defined here means in the sense of applied boundary conditions, i.e. imposed. That does not mean that you get to make up a new bizarre definition of external radiation temperature, only that it is specified There is a similar corresponding discussion for inlets in 14.3.7. For inlets, in addition to the incoming bulk temperature of the flow, you must also set the temperature of the external surface. |
May 16, 2012, 05:51 |
Vaibhav Rai Khare
Rep Power: 15 |
Hi LuckyTran.
Sorry for being so rude. Actually i got so frustrated as every person to whom i asked gave several answers and none of it helped me. If you can help me.? I am applying radiation model on a box but always getting negative heat transfer rate at absorber plate which should be positive. |
April 16, 2014, 04:36 |
#7 | |
wangyun
can you sent the fluent help to me if you have time? i don't have a clear idea for the free steam temperature and external radiation temperature. I will be very grateful to you. thank you. my email:1203596116@qq.com wang yun |
October 17, 2014, 07:50 |
#8 | |
Rep Power: 14 |
Dude I have seriously never heard such a term prior to reading it in FLUENT I have been trying to find out how FLUENT processes the External emissivity and the external radiation temperature to calculate the heat transfer to the enviornment I have goggled beyond my patience limit and still I don't find any reference to how fluent calculates radiation heat transfer from these inputs nor do I find any document under the name External Radiation, Even the FLUENT theory guide simply says this about it 4 lines not mentioning anything about the exact method Although it seems obvious it uses the t^4 (Stefan-Bolztman's Law) Have u know any document which explicitly says that? So I void verifying the same thru simulations |
August 10, 2016, 10:54 |
#9 | |
Alex Gtz
Rep Power: 10 |
where epsilon is the emissivity of the external side of the wall, sigma is the Boltzmann constant, T_inf is the external radiation temperature and T_w the temperature of the wall surface. What do you need to understand ? |
An issue with temperature change in unsteady prob | Ashok kumar | FLUENT | 1 | January 13, 2009 05:34 |
Free Stream BC | KP | FLUENT | 0 | February 27, 2006 18:28 |
Free stream B.C. | Lakshmikanth Alluru | FLUENT | 1 | February 10, 2006 00:49 |
CFX 4.4 New free surface option | Viatcheslav Anissimov | CFX | 0 | April 3, 2002 07:27 |
Temperature in vessel during throttling process | Astrid | Main CFD Forum | 2 | January 31, 2001 03:34 |
