Undeclared Identifier Errof UDF
Like Tree2Likes
  • 2 Post By Remedios
Old   March 27, 2012, 18:36
Default Undeclared Identifier Errof UDF
Stefano Capra
SteveGoat is on a distinguished road
Hi everyone,
I'm running fluent on windows xp 32bit and trying to compile a UDF with Visual Studio 9.0 (2008). I've done everything reported within this website:
-set the environmental variables for Visual Studio
-set the environmental variable for fluent
-launch fluent from the Visual C++ command window after browsing to the .cas and .dat folder
However I'm still not able to compile it correctly.
It is worth noting that the some source files compile perfectly on a Linux 64bit machine!
1 file copiati.
1 file copiati.
1 file copiati.
(system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\ntx86\3d\makefile")
1 file copiati.
(chdir "libudf")()
(chdir "ntx86\3d")()
compute_cs.c
c:\fluent.inc\fluent6.3.26\src\global.h(194) : warning C4005: 'SQR' : macro redefinition
c:\documents and settings\capra\desktop\prove fluent\libudf\src\nrutil.h(12) : see previous definition of 'SQR'
..\..\src\compute_cs.c(41) : error C2275: 'real' : illegal use of this type as an expression
c:\fluent.inc\fluent6.3.26\src\global.h(158) : see declaration of 'real'
..\..\src\compute_cs.c(41) : error C2146: syntax error : missing ';' before identifier 'd'
..\..\src\compute_cs.c(41) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(41) : error C2109: subscript requires array or pointer type
..\..\src\compute_cs.c(42) : error C2275: 'real' : illegal use of this type as an expression
..\..\src\compute_cs.c(42) : error C2146: syntax error : missing ';' before identifier 'e'
..\..\src\compute_cs.c(42) : error C2065: 'e' : undeclared identifier
..\..\src\compute_cs.c(42) : error C2109: subscript requires array or pointer type
..\..\src\compute_cs.c(43) : error C2143: syntax error : missing ';' before 'type'
..\..\src\compute_cs.c(44) : error C2143: syntax error : missing ';' before 'type'
..\..\src\compute_cs.c(45) : error C2275: 'bool' : illegal use of this type as an expression
..\..\src\compute_cs.c(10) : see declaration of 'bool'
..\..\src\compute_cs.c(45) : error C2146: syntax error : missing ';' before identifier 'use_stat'
..\..\src\compute_cs.c(45) : error C2065: 'use_stat' : undeclared identifier
..\..\src\compute_cs.c(48) : error C2065: 'use_stat' : undeclared identifier
..\..\src\compute_cs.c(49) : error C2065: 'nlambda' : undeclared identifier
..\..\src\compute_cs.c(50) : error C2065: 'nmean' : undeclared identifier
..\..\src\compute_cs.c(51) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(54) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(65) : error C2065: 'use_stat' : undeclared identifier
..\..\src\compute_cs.c(68) : error C2065: 'nmean' : undeclared identifier
..\..\src\compute_cs.c(68) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(69) : error C2065: 'nmean' : undeclared identifier
..\..\src\compute_cs.c(69) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(70) : error C2065: 'nmean' : undeclared identifier
..\..\src\compute_cs.c(70) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(79) : error C2065: 'use_stat' : undeclared identifier
..\..\src\compute_cs.c(91) : error C2065: 'use_stat' : undeclared identifier
..\..\src\compute_cs.c(93) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(94) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(95) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(96) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(97) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(98) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(99) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(100) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(101) : error C2065: 'ngrad' : undeclared identifier
..\..\src\compute_cs.c(155) : error C2065: 'n' : undeclared identifier
..\..\src\compute_cs.c(155) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(155) : warning C4047: 'function' : 'real *' differs in levels of indirection from 'int'
..\..\src\compute_cs.c(155) : warning C4024: 'tred2' : different types for formal and actual parameter 2
..\..\src\compute_cs.c(155) : error C2065: 'e' : undeclared identifier
..\..\src\compute_cs.c(155) : warning C4024: 'tred2' : different types for formal and actual parameter 3
..\..\src\compute_cs.c(157) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(157) : warning C4047: 'function' : 'real *' differs in levels of indirection from 'int'
..\..\src\compute_cs.c(157) : warning C4024: 'tqli' : different types for formal and actual parameter 1
..\..\src\compute_cs.c(157) : error C2065: 'e' : undeclared identifier
..\..\src\compute_cs.c(157) : warning C4024: 'tqli' : different types for formal and actual parameter 2
..\..\src\compute_cs.c(157) : error C2065: 'n' : undeclared identifier
..\..\src\compute_cs.c(159) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(159) : warning C4047: 'function' : 'real *' differs in levels of indirection from 'int'
..\..\src\compute_cs.c(159) : warning C4024: 'eigsrt' : different types for formal and actual parameter 1
..\..\src\compute_cs.c(159) : error C2065: 'n' : undeclared identifier
..\..\src\compute_cs.c(162) : error C2065: 'nlambda' : undeclared identifier
..\..\src\compute_cs.c(162) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(162) : error C2109: subscript requires array or pointer type
..\..\src\compute_cs.c(163) : error C2065: 'nlambda' : undeclared identifier
..\..\src\compute_cs.c(163) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(163) : error C2109: subscript requires array or pointer type
..\..\src\compute_cs.c(164) : error C2065: 'nlambda' : undeclared identifier
..\..\src\compute_cs.c(164) : error C2065: 'd' : undeclared identifier
..\..\src\compute_cs.c(164) : error C2109: subscript requires array or pointer type
..\..\src\compute_cs.c(365) : error C2275: 'Thread' : illegal use of this type as an expression
C:\Fluent.Inc\fluent6.3.26\src\mem.h(653) : see declaration of 'Thread'
..\..\src\compute_cs.c(365) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(366) : error C2275: 'cell_t' : illegal use of this type as an expression
C:\Fluent.Inc\fluent6.3.26\src\mem.h(173) : see declaration of 'cell_t'
..\..\src\compute_cs.c(366) : error C2146: syntax error : missing ';' before identifier 'c'
..\..\src\compute_cs.c(366) : error C2065: 'c' : undeclared identifier
..\..\src\compute_cs.c(367) : error C2275: 'face_t' : illegal use of this type as an expression
C:\Fluent.Inc\fluent6.3.26\src\mem.h(168) : see declaration of 'face_t'
..\..\src\compute_cs.c(367) : error C2146: syntax error : missing ';' before identifier 'f'
..\..\src\compute_cs.c(367) : error C2065: 'f' : undeclared identifier
..\..\src\compute_cs.c(370) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(370) : warning C4047: '=' : 'int' differs in levels of indirection from 'thread_struct *'
..\..\src\compute_cs.c(370) : warning C4047: '!=' : 'void *' differs in levels of indirection from 'int'
..\..\src\compute_cs.c(370) : error C2223: left of '->next' must point to struct/union
..\..\src\compute_cs.c(372) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(372) : error C2223: left of '->nelements' must point to struct/union
..\..\src\compute_cs.c(372) : error C2065: 'f' : undeclared identifier
..\..\src\compute_cs.c(377) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(377) : error C2223: left of '->flags' must point to struct/union
..\..\src\compute_cs.c(384) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(384) : error C2223: left of '->storage' must point to struct/union
..\..\src\compute_cs.c(384) : error C2065: 'f' : undeclared identifier
..\..\src\compute_cs.c(385) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(385) : error C2223: left of '->t0' must point to struct/union
..\..\src\compute_cs.c(386) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(386) : error C2223: left of '->storage' must point to struct/union
..\..\src\compute_cs.c(386) : error C2065: 'f' : undeclared identifier
..\..\src\compute_cs.c(387) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(387) : error C2223: left of '->t1' must point to struct/union
..\..\src\compute_cs.c(390) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(390) : error C2223: left of '->storage' must point to struct/union
..\..\src\compute_cs.c(390) : error C2065: 'f' : undeclared identifier
..\..\src\compute_cs.c(400) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(400) : error C2223: left of '->flags' must point to struct/union
..\..\src\compute_cs.c(407) : error C2065: 'tf' : undeclared identifier
..\..\src\compute_cs.c(407) : fatal error C1003: error count exceeds 100; stopping compilation
nrutil.c
Generating Code...
Done.
Does anyone have the same problem?
Thank you so much
Steve
SteveGoat is offline   Reply With Quote
Old   May 2, 2012, 11:04
Remedios is on a distinguished road
Could you solve this problem?
Remedios is offline   Reply With Quote
Old   May 17, 2012, 06:37
Stefano Capra
No I'm sorry
Old   May 17, 2012, 12:19
I could solve it. My problem was the UDF I was using was written in Linux and I was using it in Windows. I noticed that I needed to write my data type first. For example, for your error " 'real' : illegal use of this type as an expression", define your variable at the top of your loop before any declaration.
utkunun and Hesam_Ami like this.
Old   May 18, 2012, 04:27
Stefano Capra
Hi, that's a great news, I'm still dealing with it. What do you mean exactly? Do you declare all of them even if are local variables at the top of the code?
Thanks
STefano
Old   May 30, 2013, 19:35
Shashank
shashank312 is on a distinguished road
Remedios, could you explain on how you solved it?
shashank312 is offline   Reply With Quote
Old   April 1, 2014, 08:20
tom634 is on a distinguished road
I am facing similiar problem.
tom634 is offline   Reply With Quote
Old   October 15, 2014, 08:11
Pascal0 is on a distinguished road
According to "left of '->storage' must point to struct/union" error I had the same problem. This is a part of a code, that is supposed to calculate temperature on face, but it is not a case:
begin_f_loop(f,thr_outlet)
real area=0.0;
real NV_VEC(farea); /* defines vector "farea"*/
F_AREA(farea,f,t); /* computes area of each face */
area = NV_MAG(farea);
area_sum = area_sum + area;
sum_area_temp = sum_area_temp + area * F_T(f,thr_outlet); /* additions subsequent temperatures on faces */
end_f_loop(f,thr_outlet)
Those two thread names should be the same. I left default one after pasting from another source. After changing "f" on "thr_outlet" in "F_AREA" problem was solved. Hope this helped at least a bit.
Pascal0 is offline   Reply With Quote
compile error, udf, unclared identifier, windows xp
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 03:02
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 06:11
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
UDF compilation problem -- "undeclared variable" Henrik Ström FLUENT 1 September 21, 2005 06:25
