Compiled UDF on BATCH file
Like Tree1Likes
  • 1 Post By Bionico
Old   March 10, 2012, 10:44
Default Compiled UDF on BATCH file
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi everybody,
I have a problem running a BATCH file: it should open a certain number of simulations (case and data saved with UDF already compiled) and run them.
Nevertheless when it load the first simulation an error appears: it seems that it can't find the library (it tries to find it in the root?!!) !!
But if I load my simulation without BATCH file it finds the library in the same folder of the simulation, obviously...
Can anybody tell me how to solve my problem?
I think that maybe I have to add some commands to my BATCH file (for example a command that re-compile my UDF...)
Please help me!
PS: my batch file is quite simple, only rcd (read case and data), it # (execute a certain number of iteration) and wcd (write case and data)
souza.emer likes this.
Bionico is offline   Reply With Quote
Old   June 1, 2012, 15:57
Fer Villa
fevi84 is on a distinguished road
This is a journal file (unsteady problem) that I'm ussing:
file/read-cas-data VOFaxiNf1000-12
define/user-defined/compiled-functions load "libudf/lnamd64/2d/libudf.so"
define/user-defined/function-hooks/initialization "gas_fraction_axis::libudf.so" ""
solve/initialize/initialize-flow
file/auto-save/case-frequency if-case-is-modified
file/auto-save/data-frequency 100 (save numbered dat file every 100 time steps)
file/auto-save/root-name VOFaxiNf1000 (file format will be VOFaxiNf1000-####.dat)
file/confirm-overwrite y
solve/set/time-step 0.0001
solve/dual-time-iterate 1000 20
file/wd finVOFaxiNf1000
exit
yes
1000 = number phisical time step specified
20 = maximum number of iterations per time step
In this journal file the initialization (line red) don't work
This journal file open the library, but not initialized the UDF (my UDF is for a initial condition), the message is the follow:
Opening library "/home/####/Documents/VOFaxiNf1000/libudf/lnamd64/2d/libudf.so"...
Library "/home/#####/Documents/VOFaxiNf1000/libudf/lnamd64/2d/libudf.so" opened
gas_fraction_axis
Done.
Opening library "/home/#####/Documents/VOFaxiNf1000/libudf/lnamd64/2d/libudf.so"...
Opening library "/home/######/Documents/VOFaxiNf1000/libudf/lnamd64/2d/libudf.so"...
Library "/home/######/Documents/VOFaxiNf1000/libudf/lnamd64/2d/libudf.so" opened
> Enter Initialization function 1 from list: ("gas_fraction_axis::libudf.so" "")
Enter Initialization function 2 from list: ("gas_fraction_axis::libudf.so" "")
Updating solution at time level N...
Global Courant Number : 0.00
done.
iter continuity x-velocity y-velocity time/iter
1 1.0000e+00 1.0478e+00 0.0000e+00 0:00:00 1
1 0.0000e+00 6.5424e-02 1.2007e-05
...continue iteration
If you know why the initialization don't work, PLEASE HELP ME
fevi84 is offline   Reply With Quote
Old   June 1, 2012, 17:14
Fer Villa
Hi, again
I found the erro. The erro is not in the initialization, the erro is in the compilation due to the file ".c" was created in Windows. The file ".c" has be to created in Linux. This manner, you can interpreted or compiled the file ".c" through a journal file for running your case on Cluster.
Old   June 4, 2018, 17:44
yomnag is on a distinguished road
Originally Posted by fevi84 View Post
Hi, again
do you mean that i should create .jou file and add the udf.c commands in it
yomnag is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
