Strange error building UDF
Like Tree1Likes
  • 1 Post By villager
Old   February 15, 2012, 10:32
Default Strange error building UDF
rik
rik is on a distinguished road
Hi!
I'm trying to build an UDF with Fluent, but when I want to build it, it appears a strange error :
1 file(s) copied.
1 file(s) copied.
(system "copy "C:\PROGRAMS\FLUENT_121\v121\fluent"\fluent12.1.4\ src\makefile_nt.udf libudf\win64\3d\makefile")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\3d")()
# Generating ud_io1.h
transfert_temp.c
c:\programs\fluent_121\v121\fluent\fluent12.1.4\sr c\config.h(110) : error C2143: syntax error : missing '{' before ':'
c:\programs\fluent_121\v121\fluent\fluent12.1.4\sr c\config.h(110) : error C2059: syntax error : ':'
C:\PROGRAMS\FLUENT_121\v121\fluent\fluent12.1.4\co rtex\src\dll.h(68) : error C2061: syntax error : identifier 'CX_DLL_GetProc'
C:\PROGRAMS\FLUENT_121\v121\fluent\fluent12.1.4\co rtex\src\dll.h(68) : error C2059: syntax error : ';'
C:\PROGRAMS\FLUENT_121\v121\fluent\fluent12.1.4\co rtex\src\dll.h(68) : error C2059: syntax error : 'type'
Done.
With this UDF, I want to copy wall temperature from a wall to another.
My UDF looks like that :
#include "udf.h"
#define ID1 3
#define ID_TWIN1 13
#define MYDEBUG 1
DEFINE_ON_DEMAND(compute_twin)
Domain *d=Get_Domain(1);
face_t f,f_twin;
Thread *t_twin=Lookup_Thread(d,ID_TWIN1);
Thread *tf=Lookup_Thread(d,ID1);
real y_translation[]={0,-88,0};
real y_twin[3],y[3];
real dist=1e20;
begin_f_loop(f,tf)
F_CENTROID(y,f,tf);
NV_VV(y,=,y,-,y_translation);
begin_f_loop(f_twin,t_twin)
F_CENTROID(y_twin,f_twin,t_twin);
NV_VV(y_twin,=,y,-,y_twin);
if (NV_MAG(y_twin)<dist)
dist=NV_MAG(y_twin);
F_UDMI(f,tf,0)=f_twin;
#if MYDEBUG
C_UDMI(F_C0(f,tf),THREAD_T0(tf),0)=f_twin;
#endif
end_f_loop(f_twin,t_twin)
end_f_loop(f,tf)
DEFINE_PROFILE(apply_temp,tf,nv)
face_t f,f_twin;
begin_f_loop(f,tf)
f_twin=(int)F_UDMI(f,tf,0);
F_PROFILE(f,tf,nv)=F_T(f_twin,t_twin);
end_f_loop(f,tf)
What should have to do to erase this error? Do you have any idea?
Thanks for the help.
Ryk
rik is offline   Reply With Quote
Old   February 17, 2012, 18:04
Smile Maybe..
vlg
villager is on a distinguished road
Try this
http://www.cfd-online.com/Forums/flu...tml#post271119
You might have this problem, all error messages are the same.
"The Problem was that you didn't check the box "Visual c++ compilers" when I installed the SDK. Reinstall SDK checked that box, that will solve your problem."
I've searched in Google this string:
src\config.h error C2143: syntax error : missing '{ 'before ':'
rik likes this.
villager is offline   Reply With Quote
Old   February 19, 2012, 20:19
gearboy is on a distinguished road
Maybe you have used some non-English/unicode folder. You'd better put the case in English folders without space in folder name.
Originally Posted by rik View Post
Hi!
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
(chdir "libudf")()
transfert_temp.c
Done.
#include "udf.h"
#define ID1 3
#define ID_TWIN1 13
#define MYDEBUG 1
face_t f,f_twin;
real dist=1e20;
begin_f_loop(f,tf)
F_CENTROID(y,f,tf);
#if MYDEBUG
#endif
end_f_loop(f,tf)
face_t f,f_twin;
begin_f_loop(f,tf)
end_f_loop(f,tf)
Ryk
gearboy is offline   Reply With Quote
Old   February 21, 2012, 09:38
rik
Hy,
I've solved my problem.
I install Microsoft SDK 7.1 and Visual Studio Professionnal 2010 for windows 64 bit, and I launch Fluent with the Visual studio command prompt x64.
Thanks all for the help.
Ryk
Old   December 5, 2018, 09:35
Unhappy
amirhossein gharagoz
sadone is on a distinguished road
Hy,
Ryk
hey there ive done exact as u said and same problem
sadone is offline   Reply With Quote
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
Need help: strange problem of unsteady B.C. UDF Z. T. FLUENT 0 April 11, 2003 20:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
