February 8, 2012, 21:55 |
UDF for multicomponent particle vaporization
Mohsin Mukhtar
Rep Power: 17 |
I have coal particles surrounded by liquid water (hence multi-component). As soon as the wet coal will enter into the domain, the liquid water will evaporate into vapors and dry coal will exit the domain.
FLUENT’s inbuilt code only supports droplet (1 component) vaporization. Hence, UDF has to be written for multi-component particles. Fortunately, Fluent has provided a UDF code to solve multi-component vaporization in the following link: http://hpce.iitm.ac.in/website/Manuals/Fluent_6.3/fluent6.3/help/html/udf/node64.htm However, when I compile and hook the above UDF in DPM model of FLUENT and run the simulation, I get 0 evaporation of water. I think, there is some problem in the code and modifications have to be done in the code, as there is no mentioning of vaporization that should start when “Tp>=vap-temp” The following is the same UDF code as was seen in the link above but boiling portion is neglected(as there is no boiling in my case). Could anyone please explain what should be added here to get vaporization of water from coal particles? /************************************************** ********************* UDF for defining the heat and mass transport for multicomponent particle vaporization ************************************************** *********************/ #include "udf.h" DEFINE_DPM_HEAT_MASS(multicomponent_vaporization,p ,Cp,hgas,hvap,cvap_surf,Z,dydt,dzdt) {int ns; Material *sp; real dens_total = 0.0; /* total vapor density*/ real P_total = 0.0; /* vapor pressure */ int nc = TP_N_COMPONENTS(p); /* number of particle components */ Thread *t0 = P_CELL_THREAD(p); /* thread where the particle is in */ Material *gas_mix = THREAD_MATERIAL(DPM_THREAD(t0, p)); /* gas mixture material */ Material *cond_mix = P_MATERIAL(p); /* particle mixture material*/ cphase_state_t *c = &(p->cphase); /* cell information of particle location*/ real molwt[MAX_SPE_EQNS]; /* molecular weight of gas species */ real Tp = P_T(p); /* particle temperature */ real mp = P_MASS(p); /* particle mass */ /*..............................................*/ real molwt_bulk = 0.; /* average molecular weight in bulk gas */ real Dp = DPM_DIAM_FROM_VOL(mp / P_RHO(p)); /* particle diameter */ real Ap = DPM_AREA(Dp); /* particle surface */ real Pr = c->sHeat * c->mu / c->tCond; /* Prandtl number */ real Nu = 2.0 + 0.6 * sqrt(p->Re) * pow(Pr, 1./3.); /* Nusselt number */ real h = Nu * c->tCond / Dp; /* Heat transfer coefficient*/ real dh_dt = h * (c->temp - Tp) * Ap; /* heat source term*/ dydt[0] += dh_dt / (mp * Cp); dzdt->energy -= dh_dt; mixture_species_loop(gas_mix,sp,ns) { molwt[ns] = MATERIAL_PROP(sp,PROP_mwi); /* molecular weight of gas species */ molwt_bulk += c->yi[ns] / molwt[ns]; } /* prevent division by zero */ molwt_bulk = MAX(molwt_bulk,DPM_SMALL); for (ns = 0; ns < nc; ns++) { int gas_index = TP_COMPONENT_INDEX_I(p,ns); /* average molecular weight */ if( gas_index >= 0 ) { /* condensed material */ Material * cond_c = MIXTURE_COMPONENT(cond_mix, ns); /* vaporization temperature */ real vap_temp = MATERIAL_PROP(cond_c,PROP_vap_temp); /* diffusion coefficient */ real D = MATERIAL_PROP_POLYNOMIAL(cond_c,PROP_binary_diffus ivity, c->temp); /* Schmidt number */ real Sc = c->mu / ( c->rho * D ); /* mass transfer coefficient */ real k = (2. + 0.6 * sqrt(p->Re) * pow(Sc, 1./3.)) * D / Dp; /* bulk gas concentration (ideal gas) */ real cvap_bulk = c->pressure / UNIVERSAL_GAS_CONSTANT / c->temp * c->yi[gas_index] / molwt_bulk/ solver_par.molWeight[gas_index]; /* vaporization rate */ real vap_rate = k * molwt[gas_index] * Ap * (cvap_surf[ns] - cvap_bulk); /* no vaporization below vaporization temperature, no condensation*/ if (Tp < vap_temp || vap_rate < 0.0) vap_rate = 0.; dydt[1+ns] -= vap_rate; dzdt->species[gas_index] += vap_rate; /* dT/dt = dh/dt / (m Cp)*/ dydt[0] -= hvap[gas_index] * vap_rate / ( mp * Cp ); /* gas enthalpy source term */ dzdt->energy += hgas[gas_index] * vap_rate; P_total += cvap_surf[ns]; dens_total += cvap_surf[ns] * molwt[gas_index]; } } } Last edited by Mohsin; February 9, 2012 at 03:50. |
September 27, 2012, 02:16 |
Sujala Bhattarai
Hi, How did u solve this problem. I am also doing CFD simulation of pneumatic dryer. I followed your thread and used the multicomponent droplet (particles + water). And used the UDF Define_DPM_HEAT_MASS. And couldn't see any evaporation. I am student from KNU, south korea.
April 10, 2014, 22:16 |
multicompotent
malong
Rep Power: 13 |
dear sir ,
i am glad to meet you ,have you solved your problems about the vaporization of water using the UDF? NOW,i also meet the same issue ,canyou help me this <thankyou |
April 11, 2014, 11:37 |
Rep Power: 15 |
Does anybody know if you can use this DPM to define evaporation of water from coal in a combustion rather than multicomponent particle?
March 30, 2015, 07:12 |
Rep Power: 12 |
Maybe you can try to remove the dydt[FF] whose "FF" !=0 or 1, since dydt[0] is K/s and dydt[1..] is Kg/s.
Test which dydt[FF] using different "FF" is for water. In this UDF, "gas_index = TP_COMPONENT_INDEX_I(p,ns)" ......I don't know how to find the index and discover the number of water. what I can do is to test. |
November 10, 2016, 02:01 |
meljuntak
Rep Power: 10 |
Hi Mohsin
Do you have complite your fluent simulation??? Pleas help me..... My model almost same to your model but in transient. It's very difficult to make UDF to solve that problem thanks..... |
November 15, 2016, 02:35 |
Rep Power: 12 |
I always hope that someone who get the solution could share their method in the forum.
-- "dydt[0]" is the temperature of the particle.(Unit:K/s) You can figure this out by this line "dydt[0] += dh_dt / (mp * Cp);". "dydt[1]~dydt[aa]" is the mass fraction of the components in a particle. (Unit:Kg/s) dydt[0] is for temperature, so the value range of "aa" starts from 1. "dzdt->energy" is the enthalpy changing rate of the gas mixture in the cell where the particle is located.. (Unit:J/s) You can figure this out by the line "dzdt->energy += hgas[gas_index] * vap_rate;". "dzdt->species[gas_index]" is the mass changing rate of the component gas in the cell where the particle is located.(Unit: kg/s) The value of "gas_index" starts from 0. So what are the meanings of "[gas_index]" and "[aa]" ? For example, dydt[1]~dydt[3] = h2, o2, n2 dzdt->species[0]~dzdt->species[10] = c2h2, ch4, c3h8, h2o, n2o, n2 ... This means 3 components in a particle mixture and 11 component in the gas mixture. First, check your material list in "Mixture Species→Edit→Elected Species", and make sure the order is correct. Secondly, make sure "injection→Components→Evaporating Species" is correct. For example, you want that h2 and o2 become h2o. dydt[1] and dydt[2] will decrease as depicted in this line "dydt[1+ns] -= vap_rate". dzdt->species[3], that is the fourth component h2o, will increase as depected in this line "dzdt->species[gas_index] += vap_rate;". |
November 20, 2016, 04:26 |
#8 | |
meljuntak
Rep Power: 10 |
After I modified the UDF as your suggestion where gas index changed based on the number of particle component or species of gas. The Simulation still get an error. The errors are: 1. Simulation still gets access violation and the simulation stop, or 2. Sometimes simulation can run normally but after I check the total mass of Particle, there is no vaporization occur (total mass not reduce) . Can you give other suggestion to solve my problem??? Thanks for your response before ?? Last edited by Melvin; November 20, 2016 at 22:30. |
November 28, 2016, 04:10 |
#9 |
JUNCAI LI
Rep Power: 10 |
Hi,Melvin
I am studying this official udf case too,while,i get confused by two macros listed below. real Dp = DPM_DIAM_FROM_VOL(mp / P_RHO(p)); /* particle diameter */ real Ap = DPM_AREA(Dp); /* particle surface */ i can not find "DPM_DIAM_FROM_VOL" and "DPM_AREA" from the udf manual(version 14.5).Are they custom functions that didn't posted along with the main code? Actually,there are many macros like that in the code.can you tell why? thanks.... |
November 28, 2016, 04:22 |
#10 |
JUNCAI LI
Rep Power: 10 |
Hi,SJSW
November 28, 2016, 04:30 |
#11 |
Rep Power: 12 |
"DPM_DIAM_FROM_VOL" and "DPM_AREA" are pre-defined macro.
You can find them in udf.h or other h file. The manual did not show all the macroes and definitions. Maybe there is a complete manual about UDF. However, In most conditions, you have to ask for the support from ANSYS. The UDF must be modified to match the settings of the case. Maybe material properties, boundary conditions, Zone ID, ...and how they are defined in the codes...so I suggest that one could try to realize the meaning of the code. |
November 28, 2016, 06:00 |
#12 |
JUNCAI LI
Rep Power: 10 |
ha!,I find their definitions in dpm_tools.h.Thank you so much!
November 29, 2016, 21:32 |
#13 |
JUNCAI LI
Rep Power: 10 |
Hi,SJSW
i've compiled the udf file sucessfully in my case.however,i didn't know where to hook. There are two UDF options in decrete phase model.One is under the main dialog board of DPM and the other is under the injection board. My problem is that nothing seemd to have happened in the two places after i complied correctly.My version is 14.5.can you give me an advice?Thank you! |
November 29, 2016, 22:36 |
#14 |
Rep Power: 12 |
You can go to ANSYS Help→Fluent→Customization Manual→Creating and Using User Defined Functions→Hooking UDFs to ANSYS Fluent→ Hooking Discrete Phase Model (DPM) UDFs.
There are descriptions there. |
December 17, 2016, 22:58 |
#15 |
JUNCAI LI
Rep Power: 10 |
Hi,SJSW
In my case , i found vaporation didn't happen cause the returned value of gas_index = TP_COMPONENT_INDEX_I(p,ns) is -1.I don't know why the value is negative.Do you know the reason? Thanks |
January 26, 2021, 04:50 |
heat and mass transfer
#16 |
Sara
Rep Power: 6 |
hi all,
I'm simulating a spray dryer and i need to simulate the heat and mass transfer. when i interpret the UDF, I encounter an error. the error is: structure reference not implemented this error is about this line of code int nc = TP_N_COMPONENTS(p); /* number of particle components */ does anyone know how can I fix this error? thanks |
January 27, 2021, 02:33 |
#17 |
Alexander
Rep Power: 34 |
compile code
best regards ****************************** press LIKE if this message was helpful |
January 27, 2021, 03:57 |
#18 |
Sara
Rep Power: 6 |
thanks. I will check it
vaporization pressure UDF | Komon | Fluent UDF and Scheme Programming | 0 | September 20, 2011 20:33 |
Problem with a simple UDF to calculate cell-averaged particle values | kmayank | FLUENT | 1 | January 18, 2011 02:40 |
UDF for Particle reaction and DPM_Property | saifulraju | ANSYS | 0 | September 22, 2010 08:24 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
udf about particle concentration--who can help me? | zhaoh | FLUENT | 1 | January 17, 2007 12:46 |
