January 11, 2012, 12:13 |
How to calculate geometry diameter using UDF
Rep Power: 15 |
I dont expect to get any answer as always but any ways...
I have a cylindrical geometry with varying diameter from top to bottom. I want to specify heat loss condition since the wall is insulated. For that, I need to calculate overall heat transfer coefficient first. For that I need the inside diameter as well. Since diameter is not constant throughout the geometry, I have to find a way of calculating the distance from the centre of geometry up to the wall using UDF. Can any one help me in this? Thanks. |
January 14, 2012, 17:43 |
#2 | |
Real Name :)
Rep Power: 16 |
If you can describe your geometry before you run the simulation (it sounds like the equation for a cone), you could simply write a UDF to DEFINE_PROFILE for the heat transfer as a function of cone height.
If you write the equation of your geometry and the heat loss condition, I'll reply with a UDF which will allow you to do what you want. ComputerGuy Quote:
January 15, 2012, 06:32 |
#3 | |
Rep Power: 15 |
Thanks but I got a better solution. I can now calculate the coordinates of the nodes and using that I can get the radius. I got the solution from here: http://cape-forum.com/index.php/topic,2.0.html |
January 15, 2012, 09:23 |
#4 | |
Real Name :)
Rep Power: 16 |
Yep -- this is virtually the same solution. Glad you got your problem worked out.
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
[DesignModeler] Error while Loading a Geometry | JD944 | ANSYS Meshing & Geometry | 0 | October 25, 2011 15:51 |
udf for velocity profile in a geometry having two inlets | shubham208011 | Fluent UDF and Scheme Programming | 0 | April 6, 2009 16:13 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 12:29 |
UDF macros and updated mesh geometry | Maziar Mahzari | FLUENT | 1 | November 1, 2005 07:29 |
