what is syntax error : missing ')' before ';'
Like Tree1Likes
  • 1 Post By `e`
Old   June 20, 2011, 15:06
Default what is syntax error : missing ')' before ';'
aleisia is on a distinguished road
I'm pretty sure that I have no problem with the ‘;’ and ')', but still I got that error. Some said it is because of the compiler, but I followed the ansys technical support's direction, using vs 2010 express edition+windows sdk 7.0+.net framework 3.5 sp1 to start fluent in my win7 64bit system.
Fluent can be smoothly started without problem.
Please help.
Thanks.
Deleted old \MECHSE-JACOB-02\users\meng8\desktop estbed\libudf\win64\3ddp_host\libudf.dll
\MECHSE-JACOB-02\users\meng8\desktop estbed\libudf\win64\3ddp_node\libudf.dll
1 file(s) copied.
(system "copy "C:\ANSYSI~1\v121\fluent"\fluent12.1.4\src\makefil e_nt.udf \MECHSE-JACOB-02\users\meng8\desktop\testbed\libudf\win64\3ddp_h ost\makefile")
1 file(s) copied.
(chdir "\MECHSE-JACOB-02\users\meng8\desktop\testbed\libudf")()
(chdir "win64\3ddp_host")()
C:\Windows\twain.dll
C:\Windows\twain_32.dll
# Generating ud_io1.h
udfsource.c
..\..\src\udfsource.c(102) : error C2065: 'tepflowrate' : undeclared identifier
..\..\src\udfsource.c(102) : warning C4133: 'function' : incompatible types - from 'int *' to 'double *'
..\..\src\udfsource.c(102) : error C2065: 'vol_tot' : undeclared identifier
..\..\src\udfsource.c(105) : error C2065: 'source' : undeclared identifier
..\..\src\udfsource.c(105) : error C2065: 'tepflowrate' : undeclared identifier
..\..\src\udfsource.c(105) : error C2065: 'vol_tot' : undeclared identifier
..\..\src\udfsource.c(107) : error C2065: 'source' : undeclared identifier
..\..\src\udfsource.c(108) : error C2143: syntax error : missing ')' before ';'
..\..\src\udfsource.c(108) : error C2143: syntax error : missing ';' before ','
..\..\src\udfsource.c(108) : error C2059: syntax error : ')'
'\\MECHSE-JACOB-02\users\meng8\desktop\testbed'
CMD.EXE was started with the above path as the current directory.
UNC paths are not supported. Defaulting to Windows directory.
(system "copy "C:\ANSYSI~1\v121\fluent"\fluent12.1.4\src\makefil e_nt.udf \MECHSE-JACOB-02\users\meng8\desktop\testbed\libudf\win64\3ddp_n ode\makefile")
1 file(s) copied.
(chdir "win64\3ddp_node")()
udfsource.c
..\..\src\udfsource.c(22) : error C2143: syntax error : missing ')' before ';'
..\..\src\udfsource.c(22) : error C2059: syntax error : ')'
..\..\src\udfsource.c(23) : error C2143: syntax error : missing ')' before ';'
..\..\src\udfsource.c(23) : error C2059: syntax error : ')'
..\..\src\udfsource.c(89) : error C2143: syntax error : missing ')' before ';'
..\..\src\udfsource.c(89) : error C2059: syntax error : ')'
..\..\src\udfsource.c(90) : error C2143: syntax error : missing ')' before ';'
..\..\src\udfsource.c(90) : error C2059: syntax error : ')'
aleisia is offline   Reply With Quote
Old   June 29, 2011, 14:29
Micael
Micael is on a distinguished road
I don't know if that was your case, but there is a C rule that can be very annoying for one that is not aware of it. You should put every declaration before any operation. As an example, this produces the kind of error you got:
 int j;
 j = 1;
 int i;
Micael is offline   Reply With Quote
Old   March 10, 2015, 03:46
shivakumar is on a distinguished road
I have encountered the same problem.. Have you resolved it?
shivakumar is offline   Reply With Quote
Old   March 10, 2015, 06:59
`e`
`e` is on a distinguished road
If you have the same error then post your UDF code. The error code states the line number where the error has occurred.
`e` is offline   Reply With Quote
Old   March 10, 2015, 07:02
Unhappy
Thanks for the reply.. code is below
#include "udf.h"
#define a 340.26
DEFINE_ON_DEMAND(shock_sensor)
Domain *d;
Thread *t;
cell_t c;
d=Get_Domain(1);
real f_shock, velocity;
thread_loop_c(t,d)
begin_c_loop(c,t)
velocity=(C_U(c,t)+C_V(c,t));
f_shock = (velocity*C_P_G(c,t))/(a*abs(C_P_G(c,t)));
if(f_shock>=1)
C_UDMI(c,t,0)=f_shock;
end_c_loop(c,t)
I think I need to change the macro, but not sure...
Thanks
Old   March 10, 2015, 07:12
`e`
Are you running in serial or parallel, and what is your error message exactly?
Old   March 10, 2015, 07:15
`e`
First of all, you should declare your variables before assigning values to them as pointed out by Micael in this thread we're currently in.
Try:
Domain *d;
Thread *t;
cell_t c;
d=Get_Domain(1);
pakk likes this.
Old   March 10, 2015, 13:08
Smile
Domain *d;
Thread *t;
cell_t c;
d=Get_Domain(1);
Thank you. Awesome suggestion, my errors reduced but still got 3 errors. I think I need to change the macro, not sure. I'm running on serial right now and will attach my sensor and viscous algorithm.
UDF is this
#include "udf.h"
#define A 340.26
Domain *d;
Thread *t;
cell_t c;
d=Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
f_shock = (velocity*C_P_G(c,t))/(A*fabs(C_P_G(c,t)));
if(f_shock>=1)
end_c_loop(c,t)
Error is below.
shock_sensor.c
..\..\src\shock_sensor.c(18) : error C2297: '*' : illegal, right operand has type 'real [2]'
..\..\src\shock_sensor.c(18) : error C2440: 'function' : cannot convert from 'real [2]' to 'double'
..\..\src\shock_sensor.c(18) : warning C4024: 'fabs' : different types for formal and actual parameter 1
Done.
Thanks in advance
Old   March 10, 2015, 16:42
`e`
See my reply in this thread and please do not post duplicate questions in multiple threads.
syntax error on config.h ehooi Fluent UDF and Scheme Programming 3 November 9, 2011 11:05
[Other] Turbogrid power syntax la7low ANSYS Meshing & Geometry 0 January 15, 2011 23:20
OpenFOAM file syntax amtri OpenFOAM 5 August 28, 2010 08:19
Interpolation command '-interp-iv' in syntax file KM CFX 4 October 12, 2007 17:29
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
