How do i create time dependent flows on UDF?
Like Tree3Likes
  • 2 Post By lomba
  • 1 Post By madhan
Old   December 9, 2010, 16:22
Default How do i create time dependent flows on UDF?
Nuril
nha1g08 is on a distinguished road
How do I create this conditon using a UDF?
I want the velocity at the pipe inlet to be 10m/s from t=0 to 5
then i want the v=20m/s from t=5 to 6,
then i want the velocity again to be 10m/s from t =6 to 11
How do i set the time ticking ticking on the UDF? and what is the varaible for time?
Thanks
nha1g08 is offline   Reply With Quote
Old   December 9, 2010, 20:56
Real Name :)
ComputerGuy is on a distinguished road
nha1g08,
Try something like this. Inevitably I'm missing a semicolon in the following, but it should be relatively simple to fix. Interpret (or better, compile) this UDF, then hook it to your face velocity boundary condition. This loops over all cell faces at the inlet boundary and sets them to the given velocity depending on the simulation time.
Make sure you run transient!
Regards,
ComputerGuy
DEFINE_PROFILE(velocity_magnitude, t, i)
real velocity;
real the_current_time;
face_t f;
the_current_time = CURRENT_TIME;
if ((the_current_time>=0) && (the_current_time<5))
velocity=10;
if ((the_current_time>=5) && (the_current_time<6))
velocity=20;
if ((the_current_time>=6))
velocity=10;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = velocity;
end_f_loop(f,t)
ComputerGuy is offline   Reply With Quote
Old   December 12, 2010, 04:20
zhuliang
bright181 is on a distinguished road
I want the pressure of the pressureinlet to be 0 form 0 to 5 second
and the pressure of 8Mpa from 5 to 6 second
is it similar?
thank you in advance
bright181 is offline   Reply With Quote
Old   December 12, 2010, 09:24
Real Name :)
bright181,
Yes. You have to change the udf slightly and hook it to a different place on the inlet boundary conditions panel, but it's effectively the same. I have changed variable names for clarity.
ComputerGuy
#include "udf.h"
DEFINE_PROFILE(pressure_magnitude, t, i)
real pressure_mag;
face_t f;
if ((the_current_time>=0.0) && (the_current_time<5.))
pressure_mag=0.0;
if ((the_current_time>=5.0) && (the_current_time<6.0))
pressure_mag=8.0e6;
begin_f_loop(f,t)
F_PROFILE(f,t,i) = pressure_mag;
end_f_loop(f,t)
Last edited by ComputerGuy; December 12, 2010 at 11:27. Reason: Changed pressure from 10 --> 8 MPa
Old   January 5, 2011, 00:42
ekkapong
nuengao is on a distinguished road
Dear computerGuy
how to hook your codes to Fluent and how to set time in fluent
please give me your suggestion
thank
nuengao is offline   Reply With Quote
Old   January 5, 2011, 00:48
ekkapong
Could I have one question?
I'd like to know that how to define current time at fluent ?
Old   June 17, 2013, 04:03
Sakshi Sharma
sakshi1632 is on a distinguished road
I want to inject a fluid at every 6 mins. I prepared a code, but ther seems to be an error in line 10 saying:" line 10: invalid type for integral binary expression: double % int."
Can anyone give me a solution to this?
Thankyou.
Here's the code:
#include "udf.h"
DEFINE_PROFILE(insulin_inlet,thread,position )
{ face_t f;
begin_f_loop(f,thread)
real t = RP_Get_Real("flow-time");
if (t%360==0)
F_PROFILE(f,thread,position) = 0.1;
else
F_PROFILE(f,thread,position) = 0;
} end_f_loop(f,thread) }
sakshi1632 is offline   Reply With Quote
Old   June 17, 2013, 07:06
Default get cell value
lomba is on a distinguished road
Someone can help me please.
I would like to retrieve the value in a cell in the liquid phase and compared with a set value. Depending on the value found, I modified the condition of gas inlet. like a regulation loop.
Here is the UDF I wrote but I am having acces_violation.
the coordenates of the cell where i want get mass fraction value are x=0.08 and y=0.015
I get acess violation when i compiled my UDF.
Best regards!!!
Sorry for my english level!
#include "udf.h"
DEFINE_PROFILE(profile,thread,i)
face_t f;
cell_t c;
real YH, Rhol, ConsH, pH, pH1, cent,YH1, x, y;
real xc[ND_ND];
Thread *thread_l = THREAD_SUB_THREAD(thread,0); /*to pointer the liquid phase*/
Thread *cell_thread;
/*---mesurement---*/
/*to get cell YI value*/
begin_c_loop_all(c,cell_thread)
x=xc[0];
y=xc[1];
C_CENTROID(xc,c,cell_thread);
if( x=0.08. && y=0.015.) /*probe position*/
YH = C_YI(c,thread_l,0);
ConsH=YH*C_R(c,thread_l);
end_c_loop_all(c,cell_thread)
pH=-log(ConsH);
/*---injection CO2---*/
if(pH >7)
F_PROFILE(f,thread,i) = 1;
else
F_PROFILE(f,thread,i) = 0;
lomba is offline   Reply With Quote
Old   July 9, 2017, 12:10
Default sakshi1632
saman
sam2629 is on a distinguished road
Thankyou.
Here's the code:
#include "udf.h"
{ face_t f;
if (t%360==0)
else
hi,
did you know what was the problem of your code?
sam2629 is offline   Reply With Quote
Old   September 21, 2017, 08:57
madan
madhan is on a distinguished road
Hi everybody,
I am doing a transient simulation of conjugated heat transfer problem. In that I have a solid that plays a role of heat generation(W/m3) varying with time (q=q(t)). Since i am weak in codings, I need a help to write a udf for heat source varying with time. value is q=6.75e11
Thank you.
madhan is offline   Reply With Quote
Old   September 22, 2017, 09:57
pakk will become famous soon enough
If q=6.75e11, it is not varying in time but constant... So I think you should be more clear in what you want.
pakk is offline   Reply With Quote
Old   September 22, 2017, 15:37
madan
I found out the example source. When I tried to run transient simulation with this udf. It doesnt looklike its working. The heat generation source is increasing for every 100 sec. But when i see the avearge temperature of heat source its was almost the same for all timesteps. Hereby I have attached the Udf. Please tell me what are the mistakes I have did.
Thank You.
#define Q1 2e10
#define Q2 2.97e10
#define Q3 3.80e10
DEFINE_SOURCE(qgen_source,c,t,dS,eqn)
real source;
real time = CURRENT_TIME;
if (time <= 100) /* time 0-100 q = Q1 */
/* source term */
source = Q1;
/* derivative of source term. */
dS[eqn] = 0.;
if (time > 100 && time < 200) /* time 100-200 q = Q2 */
source = Q2;
dS[eqn] = 0.;
if (time >= 200 && time < 300) /* time 200-300 q = Q3 */
source = Q3;
dS[eqn] = 0.;
if (time >= 300 && time <400) /* time 300 -400 q = 0 */
source = dS[eqn] = 0.;
return source;
Old   September 25, 2017, 11:09
What makes you think that you made a mistake?
Old   September 25, 2017, 17:58
Default Regarding entropy generation due to heat transfer and fluid friction.
  #14
madan
Hi pakk,
I figured out the mistake.that was is in timestep size when iam iterating it..
And I have a another doubt in the entropy generation for 3d problem. I am trying to calculate entropy generation for heat transfer and fluid friction using custom field functions.
from the literature i have found that the entropy for heat transfer can be found out from following formula but for fluid friction i dont know how to implement that formula..herby i have attached the photo.
please help me about that.
Thanking you.
Ahmed Fakhrey likes this.
Old   April 4, 2018, 09:44
Tufan Özyıldız
tufygo is on a distinguished road
Originally Posted by ComputerGuy View Post
nha1g08,
Regards,
ComputerGuy
real velocity;
face_t f;
velocity=10;
velocity=20;
velocity=10;
begin_f_loop(f,t)
end_f_loop(f,t)
may you explain more i am newby and this did not work in my time dependent case
tufygo is offline   Reply With Quote
Old   February 12, 2020, 06:37
Shashank Singh
Singh3257 is on a distinguished road
nha1g08,
Regards,
ComputerGuy
real velocity;
face_t f;
velocity=10;
velocity=20;
velocity=10;
begin_f_loop(f,t)
end_f_loop(f,t)
but after 6 seconds the velocity of 10m/s will become constant and the requirement is of velocity fluctuation in every 5 second pulse.
Singh3257 is offline   Reply With Quote
Old   February 12, 2020, 06:52
Default UDF not required
  #17
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
UDF is an overkill for this work. Use a transient profile.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 13:00
Availability of previous time level values in UDF ranga sudarsan FLUENT 0 September 1, 2008 10:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
