UDF for describing non-newtonian behaviour of fiber suspension
Like Tree2Likes
  • 1 Post By shib
  • 1 Post By coglione
Old   June 11, 2010, 10:02
Default UDF for describing non-newtonian behaviour of fiber suspension
shib is on a distinguished road
I’m trying to model a fiber suspension in fluent by creating an UDF for the viscosity of the fluid. When the shear is low I want to use a Bingham model to describe the viscosity and when the flow becomes turbulent the viscosity should be equal to the turbulent viscosity.
This is how the Bingham model I’m working with looks like:
mu_a=mu+tau_0/gamma
mu_a=apparent viscosity (=effective viscosity?)
tau=stress tensor
mu=shear viscosity
gamma=second invariant of the rate of strain tensor (=shear rate?)
tau_0=yield stress
Since the function is not valid for gamma=0 I’m using an exponential regularization model:
mu_a=mu+(1-exp(-m*gamma))*tau_0/gamma
The code looks like this:
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
real mu_a;
real gamma=C_STRAIN_RATE_MAG(c,t);
real tau_0=200;
real mu_t=1;
real m=200;
real mu=0.001;
real gamma_t;
gamma_t=tau_0/(mu_t-mu);
if (gamma<gamma_t)
mu_a=mu+(1-exp(-m*gamma))*tau_0/gamma;
else
mu_a=mu_t;
return mu_a;
1. One thing I’m wondering about is how it works when I define the viscosity. I understand that the effective viscosity is a sum of the laminar and turbulent viscosity. When I use the “DEFINE_PROPERTY(cell_viscosity,c,t)” function in my code does it define the total effective viscosity for the fluid or just the laminar or the turbulent viscosity?
2. Also I’m not sure if I’ve defined the shear rate (second invariant of the rate-of strain tensor, gamma) correctly. Does anyone know if it’s correct?
3. Are there any other problems with the code or does it look ok (this is the first time I've written an UDF so I'm not sure I've used the right syntax and structure)?
Thanks for the help!
jotac likes this.
shib is offline   Reply With Quote
Old   June 14, 2010, 04:57
Max
coglione is on a distinguished road
Hello shib,
1)
hooking your code in the material property panel you will define the molecular (=laminar) viscosity.
That is, if turbulence is on Fluent will automatically compute a turbulent viscosity and sum up both to get the effective viscosity even in your laminar Bingham region.
Looking at the turbulence-panel, there is an option to set the turbulent viscosity explicitly using a udf. I think that is what you need to suppress turbulent viscosity being added in your low-shear Bingham region.
2) yes, C_SRAIN_RATE_MAG gives the second invariant as needed
cheers
jotac likes this.
coglione is offline   Reply With Quote
Old   June 15, 2010, 17:18
Thanks Max! I managed to get some pretty good results when I set the turbulent viscosity to 0.
Does anyone know how to plot the viscosity and the shear rate in CFD-post?
Fiber Suspension Solver laminar AdvaniFolgarTucker model kerstin OpenFOAM Running, Solving & CFD 6 October 28, 2020 10:03
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
