Riemann Solvers in Fluent
Like Tree1Likes
  • 1 Post By DoHander
Old   January 26, 2010, 15:06
Question Riemann Solvers in Fluent
KONSTANTINOS KARAMOLEGKOS
pbrane11 is on a distinguished road
Hello there..I am new graduate CFD student..and I am wondering is there a way to implement an approximate Riemann solver in Fluent together with a limiter. Can that be programmed in the UDF environment? Thank you very much
pbrane11 is offline   Reply With Quote
Old   January 27, 2010, 17:07
DoHander is on a distinguished road
You already have an approximate Riemann solver in Fluent (Roe-FDS scheme is a Riemann solver), check the density based solver and you will see.
About using your own UDF for this ... I don't know, check if you can add a user defined function in the Solution Control panel where you chose between Roe-FDS or AUSM. In Fluent 6.3 there is no such facility.
If you want to implement an approximate Riemann solver just to learn how to do it, start your own code use a simple geometry to avoid the need of a mesh generator ...
Do
8cold8hot likes this.
DoHander is offline   Reply With Quote
Old   January 27, 2010, 17:27
Do Hander thank you so much....I had it right in front of my eyes...you know Roe's solver was developed in the same university I am right now.
As for the code..you are right, I try to learn how to write code..I want to use a slender 3d geometry and honestly I do not have a clue how to write it with code...Thank you very much!!!!
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 05:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
