UDF interpret error with "C_CENTROID"
Like Tree1Likes
  • 1 Post By pakk
Old   September 20, 2009, 01:15
Default UDF interpret error with "C_CENTROID"
Jinfeng
Jinfeng is on a distinguished road
Hi folks,
I wrote a program to calculate the electrical body force with DEFINE_SOURCE macro. Inside the macro, C_CENTROID was used to get the coordinates of the cells (just like the DEFINE_SOURCE example in UDF manual). However, when I try to interpret the code, it gives me an error saying "line 13 C_CENTROID undeclared variable."
I can't figure out why it threw me that error! Does anybody know what's going on? Any help would be greatly appreciated! Thanks.
The following code is the DEFINE_SOURCE part:
#include "udf.h"
DEFINE_SOURCE(xmom_source, c, t, dS, eqn)
int i; // index for the nodes
float startx; // x coordinate of nearest node to interpolation node with lower x value
float starty; // y coordinate of nearest node to interpolation node with lower y value
float startz; // z coordinate of nearest node to interpolation node with lower z value
float xinterpfact, yinterpfact, zinterpfact;
float newrho;
float newdvdx, newdvdy, newdvdz;
float xinterp1, xinterp2, xinterp3, xinterp4;
float yinterp1, yinterp2;
real x[ND_ND];
real source;
C_CENTRIOD(x,c,t);
xinc = xdomain/(xdirnodes-1);
yinc = ydomain/(ydirnodes-1);
zinc = zdomain/(zdirnodes-1);
startx = ((
int)(x[0]/xinc))*xinc;
xinterpfact = (x[0] - startx)/xinc;
starty = ((
int)(x[1]/yinc))*yinc;
yinterpfact = (x[1] - starty)/yinc;
startz = ((
int)(x[2]/zinc))*zinc;
zinterpfact = (x[2] - startz)/zinc;
i = xdirnodes*ydirnodes*startz/zinc + xdirnodes*starty/yinc + startx/xinc;
//*** INTERPOLATE RHO ***//
xinterp1 = xinterpfact*(rho[i+1]-rho[i]) + rho[i];
xinterp2 = xinterpfact*(rho[i+xdirnodes+1]-rho[i+xdirnodes])+rho[i+xdirnodes];
xinterp3 = xinterpfact*(rho[i+xdirnodes*ydirnodes+1]-rho[i+xdirnodes*ydirnodes])+rho[i+xdirnodes*ydirnodes];
xinterp4 = xinterpfact*(rho[i+xdirnodes+xdirnodes*ydirnodes+1]-rho[i+xdirnodes+xdirnodes*ydirnodes])+rho[i+xdirnodes+xdirnodes*ydirnodes];
yinterp1 = yinterpfact*(xinterp2-xinterp1)+xinterp1;
yinterp2 = yinterpfact*(xinterp4-xinterp3)+xinterp3;
newrho = zinterpfact*(yinterp2-yinterp1)+yinterp1;
//*** INTERPOLATE DVDX ***//
xinterp1 = xinterpfact*(dvdx[i+1]-dvdx[i]) + dvdx[i];
xinterp2 = xinterpfact*(dvdx[i+xdirnodes+1]-dvdx[i+xdirnodes])+dvdx[i+xdirnodes];
xinterp3 = xinterpfact*(dvdx[i+xdirnodes*ydirnodes+1]-dvdx[i+xdirnodes*ydirnodes])+dvdx[i+xdirnodes*ydirnodes];
xinterp4 = xinterpfact*(dvdx[i+xdirnodes+xdirnodes*ydirnodes+1]-dvdx[i+xdirnodes+xdirnodes*ydirnodes])+dvdx[i+xdirnodes+xdirnodes*ydirnodes];
newdvdx = zinterpfact*(yinterp2-yinterp1)+yinterp1;
source = newrho*newdvdx;
dS[eqn] = 0.0;
return source;
Jinfeng is offline   Reply With Quote
Old   September 20, 2009, 06:16
Bernhard
Bernhard is on a distinguished road
It will help when you show the relevant part of your UDF. Now I can only guess for possible errors in your code.
Bernhard is offline   Reply With Quote
Old   September 25, 2009, 11:55
Akour
ak6g08 is on a distinguished road
you have spelt C_CENTROID incorrectly...youve got C_CENTRIOD.
akour
ak6g08 is offline   Reply With Quote
Old   September 26, 2009, 18:40
Jinfeng
Thank you so much, akour! I just realized how stupid the mistake was! Oh, damn......
Old   November 5, 2020, 11:02
abdo
khaledhmz is an unknown quantity at this point
this is my udf:
#include "udf.h"
#include "mem.h"
#define Y_CH4_in 0.032
#define Y_O2_in 0.225
DEFINE_PROFILE(mass_fraction, t, i)
face_t f;
begin_f_loop(f, t)
F_CENTROID(x, f, t);
F_PROFILE(f, t, i) = Y_CH4_in;
F_PROFILE(f, t, i) = Y_O2_in;
end_f_loop(f, t)
khaledhmz is offline   Reply With Quote
Old   November 6, 2020, 07:33
pakk will become famous soon enough
Interesting code, I see that it is still the same as several days ago, so the same problems are there. If you don't understand suggestions, ask for clarification, don't just ignore the help you get and ask the question again...
khaledhmz likes this.
pakk is offline   Reply With Quote
Old   November 6, 2020, 16:38
abdo
Hello, I correct some error and it compile but there are other error related to the temperature that why I repulish the new one.I can't change the concentrations of each species.
Can not to interpret UDF AlexanderSventitskiy FLUENT 4 August 18, 2011 09:10
interpret or compile an UDF (emergency) Lotfi FLUENT 1 August 26, 2007 13:58
Not able to interpret UDF Prasad FLUENT 1 August 15, 2007 09:44
Interpret three UDF for property Atsu FLUENT 4 April 22, 2006 16:04
UDF Interpret - Syntax Error Leonard FLUENT 1 October 22, 2005 11:06
