Adding Custom Tab in FLUENT using Scheme Code
Like Tree2Likes
  • 2 Post By dhimans
Old   September 14, 2009, 16:10
Default Adding Custom Tab in FLUENT using Scheme Code
Dhiman
dhimans is on a distinguished road
Hi ,
I have a scheme code with which I can add a custom tab in FLUENT for inputting my GLOBAL variables for an automation code (again in Scheme).
The Tab works fine in GUI but I get junk values of those global variables when I try to retrieve them.
I want to be able to access the values of those global variables at all times.
The Code is -----------------------------------------------------------------------
;------------ Create RPVARS for Input parameters----------------------
(if (not (rp-var-object 'c_1))(rp-var-define 'c_1 550 'real #f))        ;corresponds to default mainstream gas temp
(if (not (rp-var-object 'c_2))(rp-var-define 'c_2 60 'real #f))         ;corresponds to default mainstream velocity
(if (not (rp-var-object 'c_3))(rp-var-define 'c_3 1.5 'real #f))        ;corresponds to default turbulent intensity
(if (not (rp-var-object 'c_4))(rp-var-define 'c_4 300 'real #f))        ;corresponds to default coolant gas temp
(define Tgas)          ; 4 Global variables
(define Vgas)
(define I)
(define Tcool)
(define gui-icht
  (let ((panel #f))
          (define (update-cb  args)           ;update panel fields
   (cx-set-real-entry Tgas (rpgetvar 'c_1))
   (cx-set-real-entry Vgas (rpgetvar 'c_2))
   (cx-set-real-entry I (rpgetvar 'c_3))
   (cx-set-real-entry Tcool (rpgetvar 'c_4))
       (define (apply-cb  args)
   (rpsetvar 'c_1 (cx-show-real-entry Tgas))
   (rpsetvar 'c_2 (cx-show-real-entry Vgas))
   (rpsetvar 'c_3 (cx-show-real-entry I))
   (rpsetvar 'c_4 (cx-show-real-entry Tcool))
       (lambda (args)
(if (not panel)
(let ((table) (form))
(set! panel (cx-create-panel "ICHT PANEL" apply-cb update-cb))
(set! table (cx-create-table panel "" 'border #f 'below 0 'right-of 0))
(set! form (cx-create-frame table "" 'border #f))
(set! Tgas (cx-create-real-entry table "Tg" 'width 14 'row 1 'col 0 ))
(set! Vgas (cx-create-real-entry table "Vg" 'width 14 'row 2 'col 0 ))
(set! I (cx-create-real-entry table "Tu%" 'width 14 'row 3 'col 0 ))
(set! Tcool (cx-create-real-entry table "Tc" 'width 14 'row 4 'col 0))
(set! *cx-exit-on-error* #f)
(cx-show-panel panel))
    ); END OF LET SCOPE
); END OF FUNCTION DEFINITION
(let ((menu (cx-add-menu "ICHT-GUI-Beta" #\U ))); end of let list
      (cx-add-item menu "PARAMATERS"  #\U #f cx-client? gui-icht)
      (cx-add-item menu "START PROGRAM" #\O #f and (lambda ()(load "main.scm"))); Starts the main automation code
I wish to load the custom tab ... Update the values .. and Retrieve the values anywhere in the main program. But when I try doing that get a Junk Value.
Please help me out with this
Regards
Dhiman
mm.abdollahzadeh and crevoise like this.
dhimans is offline   Reply With Quote
Integrating Scheme with a FLUENT journal file Pete Willemsen FLUENT 0 May 19, 2006 18:00
Adding a pause to a fluent journal Baoun FLUENT 0 April 24, 2006 05:44
Central Differencing Scheme in Fluent alice FLUENT 2 March 21, 2004 08:30
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
Fluent Code (4.2 V) Limitations John Peter Main CFD Forum 1 July 25, 1998 05:51
