Error: CAR: invalid argument [1]: wrong type [not a pair]??? |
August 22, 2009, 08:21 |
Paul
What does this error mean?
March 13, 2010, 14:39 |
same problem
amirbahador
Rep Power: 16 |
HI dude
I have same problem now ....have u fix it by now ...pls help me to solve my problem |
April 27, 2010, 08:53 |
Rep Power: 16 |
Ok you need to explain which function call gives you this. Usually this comes from the scheme interpreter. It means that some scheme function received the wrong arguments.
Please explain more. |
April 28, 2010, 12:07 |
Rep Power: 17 |
(car "xxx") ; When using 'car', its argument should be a list. |
March 30, 2011, 16:19 |
Jeremy Allen
Rep Power: 16 |
I received this same error message when trying to add source and sink terms to separate cell zones. It was confusing me because sometimes I would receive the error and sometimes I wouldn't.
I talked with ANSYS customer support today and they told me that it had to do with problems with the code when using the GUI. Their suggestion was to close Fluent and start it up again. I had already tried this once and it didn't help. However, at the suggestion of the customer service rep I tried it again and it worked the 2nd time. I was able to add the source and sink terms and did not receive an error. I don't know if this will help for every case where this error message appears, but it's worth a try. |
October 28, 2012, 06:10 |
Rick
Rep Power: 27 |
I also received this error for a double periodic domain, when trying to plot contour or define periodic planes; my domain is a slice of a tube translational periodic in z direction and rotational periodic around z axis.
However I have no problems in postprocessing with CFD-POST. |
October 28, 2012, 10:01 |
I don't get any problem while defining the periodic planes or contour plot on periodic boundaries.
August 30, 2013, 07:28 |
aditya chiliveri
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 18:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
Parallel FOAM FATAL IO ERROR | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | July 28, 2006 13:48 |
error: CDR: invalid argument [1]: wrong type | Marc | FLUENT | 0 | July 24, 2006 06:59 |
