problem with UDF for (v2-f) turbulence model in fluent
Like Tree1Likes
  • 1 Post By artemiss1984
Old   May 12, 2009, 10:39
Default problem with UDF for (v2-f) turbulence model in fluent
artemiss1984 is on a distinguished road
Hi.
I found the v2-f UDF (Durbin turbulence model) to link with fleunt software, but it contains several errors when I compile it. I also use interpret option for udf in fleunt but it is not working.what is the problem? please help me.
(I found two papers that the writers claimed that they could do this work without any problem.)
artemiss1984 is offline   Reply With Quote
Old   May 15, 2009, 06:49
Amol Ramteke
Goldsstean is on a distinguished road
Cheak with header file, and the udf use
Goldsstean is offline   Reply With Quote
Old   May 20, 2009, 17:29
bluelc is on a distinguished road
You post the udf and corresponding papers here, and we can help you check it out.
bluelc is offline   Reply With Quote
Old   June 5, 2009, 17:51
thabk you.here is the udf.
mostafadehghani likes this.
Old   June 13, 2009, 10:39
any reply? I am waiting for anyone using this turbulence model.also this model released via the original package of FLUENT. could anyone check it?
Old   August 23, 2009, 05:59
John Yang
1682333 is on a distinguished road
Sorry,but I can't help on the UDF file.
If you use Fluent 6.3.26,you can activate v2f model by typing
(allow-v2f-model)
in the console window.
1682333 is offline   Reply With Quote
Old   January 17, 2014, 06:50
Default Udf
Kanarya is on a distinguished road
Hi artemiss1984,
I would like to use this udf but I do not understand in which equation they use the UDS_FLUX and how program recognize the difference between UDS_FLUX cases and diffusivity cases as they have same name?
I am trying to solve simple pipe flow but I am getting access violation errors.
can you help me in order to solve this problem!
thanks in advance!
Kanarya is offline   Reply With Quote
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 7, 2018 00:37
Turbulence model problem? PattiMichelle Phoenics 0 July 11, 2007 20:35
Turbulence modeling for fan/compressor blading Jonas Larsson FLUENT 1 April 13, 2005 15:08
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
