How to make a UDF to have a velocity profile in a square channel
Like Tree6Likes
  • 3 Post By Daniel Tanner
  • 2 Post By Daniel Tanner
  • 1 Post By Daniel Tanner
Old   May 12, 2009, 10:22
Default How to make a UDF to have a velocity profile in a square channel
Gigis is on a distinguished road
i have a 3D domain as a square channel. I had set the inlet as velocity inlet in Gambit..And now come into Fluent, i have to use a UDF programming to set a parabolic flow veloctiy inlet and difference pressure at the inlet.. But i dont know how to write a programme about this 3D domain... Anyone can help? thanks
Here is what I tried:
vprofile.c
UDF for specifying steady-state velocity profile boundary condition
#include "udf.h"
#include "iostream"
DEFINE_PROFILE(inlet_x_velocity, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y, z;
face_t f;
x[0]=0.07
begin_f_loop(f, thread)
for(i=1:15;i=i+2)
F_CENTROID(x, f, thread); /*fluent finds an error in this line, why??*/
y = x[0];
z = x[0];
F_PROFILE(f, thread, position)=(4.*0.0005*0.0005*0.1/(3.14*3.14*3.14*0.001*0.006))*sigma((1/(i*i*i))*(1-((cosh(i*3.14*y/0.0005))/(cosh(i*3.14/2))))*(sin(i*3.14*z/0.0005));
end_f_loop(f, thread)
Gigis is offline   Reply With Quote
Old   May 12, 2009, 17:03
Daniel Tanner
Daniel Tanner is on a distinguished road
The UDF looks ok, though I think you are not understanding the UDF or "position vector" fully.
begin_f_loop(f, thread) is used to loop over every element (face) on the inflow boundary.
F_CENTROID(x, f, thread) returns the "position vector" (x) of the centroid of each face for every iteration of the loop. The "position vector" is x[] where x[0] is the x value, x[1] is the y value and x[2] is the z value of each centroid. Remember there is one centroid for each face element of the inlet surface. NOTE: you have used x[0] = 0.07 before the loop, this is meaningless as it will be overwritten by F_PROFILE at each iteration.
F_PROFILE(f, thread, position) allows you to prescribe the value of a variable at this inlet surface, e.g., the velocity at each wall centroid. Hence, y = x[0] and z = x[0] just means that all are X position. Note: ND_ND tells the UDF if you are running a 2D or 3D solver, hence, x holds three values.
Your loop looks strange, check the syntax, i.e., "for(i=1:15;i=i+2)" might be something like "for(i = 0; i < 10; i++)". You must also define i, i.e., "int i;"
Does this answer your problem? If not submit the actual error or the nature of the error (e.g., non-sensible values, compilation problems ...).
soheil_r7, roi247 and mCiFlDk like this.
Daniel Tanner is offline   Reply With Quote
Old   May 12, 2009, 18:43
Thanks for reply
This is my new UDF below, But I still do not understand everything into.
It does not works anymore. Fluent says:" ligne 17 invalid lvalue in assignment".
Could you help me a little bit again?
Thank you
Gigis
vprofile.c
#include "udf.h"
#include "iostream"
real y, z;
face_t f;
x=x[0]
(L.17) begin_f_loop(f, thread)
int i
for(i = 0; i < 10; i+=2)
y = x[1];
z = x[2];
Old   May 13, 2009, 11:55
Daniel Tanner
Some quick observations:
1) the "int i;" command must come at the start with the rest of the declared variables (i.e., x, y, z ...)
2) all lines must finish with ";"
3) better to use x[0], x[1] and x[2] directly (not x, y, z)
#include "udf.h"
#include "iostream" /* Don't know why you need this and should probably be "iostream.h"*/
real x[ND_ND]; /* this will hold the position vector, these are real numbers */
int i; /* i is an integer and statement must finish with ";"*/
face_t f;
x=x[0]; /* you had no semi-colon and this means nothing, it will be overwritten in the next loop! So best to remove it!*/
begin_f_loop(f, thread) /* this is the loop that iterates through every element on the inlet boundary!!!! This is the same as a for(i = 0; i < Number_of_elements_on_inlet_face; i++)*/
for(i = 0; i < 10; i+=2) /* what does this do??????? This will stop the boundary condition from being applied to every part of the inlet */
F_CENTROID(x, f, thread); /* this statement returns the centroid location to position vector x, hence above x = x[0]; means nothing. */
/* The next line prescribes the calculated value as a boundary condition (e.g., velocity) for the current inlet element. Hence, the loop Begin_f_loop iterates through each element and prescribes the boundary condition based on its location, which is determined by F_Centroid */
F_PROFILE(f, thread, position)=(4.*0.0005*0.0005*0.1/(3.14*3.14*3.14*0.001*0.006))*sigma((1/(i*i*i))*(1-((cosh(i*3.14*x[1]/0.0005))/(cosh(i*3.14/2))))*(sin(i*3.14*x[2]/0.0005));
shubhangini and Sai Krishna like this.
Old   May 13, 2009, 12:01
Daniel Tanner
See the example below! This will write a profile to the inlet face. For a velocity inlet boundary condition this is effectively setting a velocity at each inlet element as a function of the x*y*z location of each face centroid!
I hope this helps!
#include "udf.h"
real x[ND_ND];
face_t f;
F_PROFILE(f, thread, position)= x[0]*x[1]*x[2]; /* same as x*y*z */
soheil_r7 likes this.
Old   May 14, 2009, 16:39
OK thanks for the answer,
So, I tried to arrange my UDF and now it seems to work! I just made another one more simple. without the sum (=sigma) et without "for(i = 0; i < 10; i+=2)" so.
But, now, the matter is there is not the velocity value I want. The maximum value is about 0.00032m/s, While in the UDF i defined x[0]=0.07m/s.
It is one thing I cannot understand, could you please explain me or give me a solution?
Thanks a lot
Regis
Here my UDF:
vprofile.c
#include "udf.h"
#include "iostream.h"
face_t f;
x[0]=0.07;
F_PROFILE(f, thread, position)=(4.*0.0005*0.0005*0.1/(3.14*3.14*3.14*0.001*0.006))*(((1/(1*1*1))*(1-((cosh(1*3.14*x[1]/0.0005))/(cosh(1*3.14/2))))*(sin(1*3.14*x[2]/0.0005)))+((1/(3*3*3))*(1-((cosh(3*3.14*x[1]/0.0005))/(cosh(3*3.14/2))))*(sin(3*3.14*x[2]/0.0005)))+((1/(5*5*5))*(1-((cosh(5*3.14*x[1]/0.0005))/(cosh(5*3.14/2))))*(sin(5*3.14*x[2]/0.0005)))+((1/(7*7*7))*(1-((cosh(7*3.14*x[1]/0.0005))/(cosh(7*3.14/2))))*(sin(7*3.14*x[2]/0.0005))));
Old   May 14, 2009, 17:40
Daniel Tanner
Sorry if I was unclear!
Firstly, you set x[0] = 0.07 but it does not appear in your equation for the profile! If you wish to insert it then you can just insert 0.07 directly, i.e., (10*x[1])+1 is the same as (10*0.07)+1.
Secondly, if you wish to use x[0] = 0.07 then you must do so after the F_CENTROID command as this sets x[0] to the x value of the centroid of the current face! i.e.:
x[0]=0.07;
F_PROFILE(f, thread, position)=.....
Thirdly, I am not an expert in C but I would suggest that you do not use integers in your calculations. In some programming languages this can lead to the processor performing an integer calculation rather that single or double precision, i.e. replace (1/(1*1*1)) with (1.0/(1.0*1.0*1.0)). Not sure if it makes a difference in Fluent but no harm to include the first decimal place.
Finally, if the profile is correct but the peak value is not as desired then just multiply everything to scale to the correct peak value, i.e. if you want a peak of 1 m/s then multiply the profile by 1/0.00032:
F_PROFILE(f, thread, position)=(1.0/0.00032)*.....
Old   September 3, 2012, 07:59
n7310889
n7310889 is on a distinguished road
Hi Dani,
I'm writing an udf to assign heat generation profile in the outer wall of (symmetric right hand side half section) of a 3D annular fluid domain of 33mm radius. This fluid is flowing through a 35 mm radius and 8 m long horizontal tube. The heat generation (q) profile varies along the circumference (horizontal x & vertical y direction) of the tube, and assumed constant & steady state along the length (horizontal z direction). Coordinates of the axis of rotation of the tube are (0,0,0) and (0,0,8.0).
My earnest request to you, please check the udf written for a Fluent 3D model. I'll remain grateful to you. Also please check the logic of assigning radius value in the macro. Since my model contains only fluid domain of 33 mm, then what should be assigned value for radius among 33 mm of fluid body or 35 mm including tube? Please suggest me.
#include "udf.h"
#define RADIUS 0.033
#define CONVEC_LOS_COFICENT 0.05
#define TUBE_EMISIVITY 0.1378
#define GLAS_EMISIVITY 0.05
#define SIGMA 5.67e-08
#define DIRECT_NORMAL_INSOLATION 937.9
#define T_KELVIN 273.0
DEFINE_PROFILE(wallheatfluxprofile,thread,index)
real x[ND_ND];
real glas_tube_emsivity,T_amb,T_sky,T_glass,T_gas,rad_l oss,convec_loss;
double a,z,q;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
glas_tube_emsivity=(TUBE_EMISIVITY*GLAS_EMISIVITY)/((TUBE_EMISIVITY+GLAS_EMISIVITY-(TUBE_EMISIVITY*GLAS_EMISIVITY));
T_amb =T_KELVIN+28.5;
T_sky =T_KELVIN+14.0;
T_glass =T_KELVIN+121.0;
T_gas =T_KELVIN+30.0;
rad_loss =TUBE_EMISIVITY*SIGMA*((2*pow(WALL_TEMP_INNER (f,thread),4)-pow(T_amb,4)-pow(T_sky,4))+glas_tube_emsivity*SIGMA*(pow(WALL_T EMP_INNER (f,thread),4)-pow(T_glass,4));
convec_loss =CONVEC_LOS_COFICENT*(WALL_TEMP_INNER (f,thread)- T_gas);
z=x[2];
for(z=0.0; z<=1.5; z++)
if((z>=0.0) && (z<=1.2))
for(a=0.0; a<=180.0; a++)
x[0] =RADIUS*sin(a);
x[1] =-RADIUS*cos(a);
if ((a>=0.0) && (a<=15.9))
q =4.1643*pow(a,3)-60.818*pow(a,2)+485.19*a+32320;
if ((a>15.9) && (a<=47.5))
q =0.1288*pow(a,3)-6.7478*pow(a,2)+293.03*a+37992;
if ((a>47.5) && (a<=86.5))
q =1.2582*pow(a,3)-256.73*pow(a,2)+15690*a-250299;
if ((a>86.5) && (a<=180.0))
q =-0.0004*pow(a,3)-0.0716*pow(a,2)+47.947*a-3026.1;
F_PROFILE(f,thread,index) =(q*DIRECT_NORMAL_INSOLATION/937.9)-rad_loss-convec_loss;
else
F_PROFILE(f,thread,index) =0.0;
end_f_loop(f,thread)
n7310889 is offline   Reply With Quote
Old   January 13, 2013, 23:20
Default output value in DOS window
mactech001 is on a distinguished road
Dear Daniel,
hello.
i would like to output the value i apply to F_PROFILE to the DOS window by using 'cout'. the following is my code:
#include "udf.h"
DEFINE_PROFILE(wallheatgenerate,thread,i)
real source=0.001;
face_t f;
F_PROFILE(f,thread,i)=source+0.001;
cout<<"F_PROFILE output:"<<F_PROFILE(f,thread,i)<<endl;
but, in Fluent, the compiling claims that it can't open the include file "iostream.h".
can you help me to see what's wrong with the code please?
my compiler is VS C++ 2008 express, and it compiles the 'Hello world' code fine with no problems.
Thank you for your kind attention.
Kind regards,
mactech001
Currently using: ANSYS v13
mactech001 is offline   Reply With Quote
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
Associating profile files for the UDS though a UDF Bharath FLUENT 0 December 1, 2006 16:58
UDF for square wave velocity profile..pls help Frederik FLUENT 0 May 8, 2006 07:48
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 13:32
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
