Defining species mass fraction using a UDF
Like Tree3Likes
  • 1 Post By T81
  • 2 Post By coglione
Old   March 25, 2009, 12:06
Default Defining species mass fraction using a UDF
T81
T81 is on a distinguished road
Hi there,
I'd like to know how to define species mass fraction with a UDF.
I found the macro C_YI(c,t,i), for defining the species mass fraction.
But how to hook this in fluent?
Probably under inlet at the boundary conditions panel,
but which is the appropriate general-purpose macro for this?
I tried the following but the mass fraction doesn't change.
DEFINE_PROFILE(species_profile, t, position)
  cell_t c;
  begin_c_loop(c, t)
    if (temp_avg  > 700)
       C_YI(c,t,0) = 0.2;
    else
       C_YI(c,t,0) = 0.8;
 end_c_loop(c, t)
Thanks in advance
khaledhmz likes this.
T81 is offline   Reply With Quote
Old   March 26, 2009, 03:57
Max
coglione is on a distinguished road
DEFINE_PROFILE has to return a value using C_PROFILE(c,t,i):
DEFINE_PROFILE(species_profile, t, i)
cell_t c;
begin_c_loop(c, t)
if (temp_avg > 700)
C_PROFILE(c,t,i) = 0.2;
else
C_PROFILE(c,t,i) = 0.8;
end_c_loop(c, t)
}Hook it in the boundary condition panel for your fluid zone(s) and make sure that Sum[C_YI(i)] = 1 is still valid after executing this UDF !
cheers
soheil_r7 and souza.emer like this.
coglione is offline   Reply With Quote
Old   March 26, 2009, 04:59
T81
coglione thank you very much for the quick response.
It works!!!
Thanks again
Old   April 19, 2018, 08:02
pornthep sittisak
Pom Sittisak is on a distinguished road
I need co mass fraction from back surface of the fan (ID=5) to use as CO species of outlet at front of the fan.
I also try to find the cause of this error when in try to put below UDF in my problem.
Error: received a fatal signal (Segmentation fault).
Error Object: #f
Here my UDF, aim to bring the CO (species mass fraction) variable data from back to front of the long cylinder tube.
#include "udf.h"
//Global variable declaration
real co;
//Execute every timestep
DEFINE_EXECUTE_AT_END(Fanback)
//Specific the domain ** 1 = mixture domain
Domain *mix_domain = Get_Domain(1);
Thread *mix_thread;
Thread **pt;
//Initialize the variable
co = 0;
#if !RP_HOST
mp_thread_loop_f(mix_thread, mix_domain, pt)
face_t c;
// pt[0] ** number [0] is co phase index (co in this case)
begin_f_loop(c, pt[0])
// Check if it is a outlet thread (thread id = 5) (Lookup from region list)
if (THREAD_ID(mix_thread)==5){
// Loop and sum up the flux for each face
co =F_YI(c,pt[0],1);
end_f_loop(c, pt[0])
#endif /* !RP_HOST */
node_to_host_real_1(co);
#if RP_HOST
Message("CO Concentration at FAN BACK = %f\n",co);
#endif /* !RP_NODE */
// Creating profile for returning inlet
DEFINE_PROFILE(co_outlet,t,i)
face_t f;
begin_f_loop(f,t)
//Apply flowout variable to the face
F_PROFILE(f,t,i) = co;
end_f_loop(f,t)
I can pass the complied and Hook the run the simulation using these UDF but the error is shown when first the time step is finished.
Pom Sittisak is offline   Reply With Quote
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 12:29
UDF for Species mass fraction daniel FLUENT 3 June 22, 2005 09:40
UDF for Species mass fraction Rahul FLUENT 0 September 20, 2002 05:22
Species Mass Fraction inside UDF using PDF? Daniel Schneider FLUENT 0 September 20, 2000 07:34
