Udf for a fully developed velocity profile atinlet
Like Tree4Likes
  • 1 Post By AYOUB
  • 2 Post By vicarious
  • 1 Post By `e`
Old   May 15, 2006, 14:55
Default Udf for a fully developed velocity profile atinlet
philip meppen
I need to specify a boundary condition at the inlet region of a square duct. At the inlet i want to specify a fully developed velocity profile. I know i need to use a UDF. The fluent manual gives examples of a fully developed velocity profile at the inlet for a 2d example but not 3d. Has anybody ever done this. would you be willing to send me your c code if you have?
Old   May 16, 2006, 05:10
Default Re: Udf for a fully developed velocity profile ati
houston
Hi, meppen, I have met a question, it seems that you could help me.I don't know where can I find an example of a fully developed velocity profile at the inlet for a 2d example using UDF.Thanks in advance. sincerely, houston
Old   May 26, 2006, 15:06
Colin
Philip,
click the following link:
http://www.cfd-online.com/Search/cgi...cfd-online.com%2FForum%2Ffluent;exclude=;config=htdig;method=and ;sort=score;words=velocity%20profile;page=1
and then read the post titled as:
Re: problem in 3d parabolic velocity profile****
You will get some ideas about the C code for 3D.
By the way, could you send me the c code for 2D fully developed velocity profile?
Old   November 7, 2012, 05:47
Ayoub
AYOUB is on a distinguished road
Originally Posted by philip meppen
;132225
Hi, I need the UDF for 2D. would you pleas give me?
mustafa2iraq likes this.
AYOUB is offline   Reply With Quote
Old   November 7, 2012, 07:33
vicarious's Avatar
Pedram Mojtabavi
vicarious is on a distinguished road
Send a message via Yahoo to vicarious
Example of a parabolic velocity profile in 2D:
#include "udf.h"
DEFINE_PROFILE(x_velocity,thread,index)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f,thread,index) = 20. - y*y/(.0745*.0745)*20.;
end_f_loop(f,thread)
Ref. : FLUENT UDF manual.
Mahesh7238 and rajann_786 like this.
vicarious is offline   Reply With Quote
Old   November 7, 2012, 10:49
Default thernall fully developed
Ayoub
thank you, but is it suitable to reach thermal fully developed?if not what is your suggestion?
Old   November 7, 2012, 15:30
vicarious's Avatar
Pedram Mojtabavi
I'm not exactly sure about the thermal boundary layer, but since the parabolic profile is suitable for the laminar flow boundary layer (for Re lower than 1000), I suppose it is correct to use it in a numerical procedure.
Old   October 8, 2015, 10:52
CaptainCombo is on a distinguished road
#include "udf.h"
real x[ND_ND];
real y;
face_t f;
y = x[1];
F_PROFILE(f,thread,index) = y;
I build this code and loaded it then I initialized this profile for inlet velocity but when I plot it by using Solution XY Plot(before solving, just initialization) I get uniform velocity profile. Velocity values don't change along y axis. What is the problem?
Here are values;
(title "X Velocity")
(labels "Position" "X Velocity")
((xy/key/label "inlet")
5.73798 0
4.78165 2.86899
3.82532 2.86899
2.86899 2.86899
1.91266 2.86899
0.95633 2.86899
0 0
CaptainCombo is offline   Reply With Quote
Old   October 8, 2015, 16:17
`e`
`e` is on a distinguished road
Here are values;
Try solving at least one iteration and then checking the inlet velocity profile. If 2.86899 m/s is your average inlet velocity (and the previous step worked) then perhaps the Fluent initialisation applies this value, and then the profile is called at the start of each iteration.
CaptainCombo likes this.
`e` is offline   Reply With Quote
Old   October 12, 2015, 05:17
Results after one iteration;
(title "Velocity Magnitude")
(labels "Position" "Velocity Magnitude")
5.73798 0
4.78165 4.78165
3.82532 3.82532
2.86899 2.86899
1.91266 1.91266
0.95633 0.95633
0 0
It requires at least one iteration to update.
Old   November 3, 2015, 16:56
Default udf
  #11
abdi mohamed
abdi mohamed1 is on a distinguished road
I*need UDF velocity profile fully developed turbulent flow for cylinder 3d please.
abdi mohamed1 is offline   Reply With Quote
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 20:08
Fully developed 3d velocity profile: Square inlet! Taru FLUENT 6 September 14, 2015 09:38
3D UDF Paraboilc Velocity Profile with max velocity johnGo Fluent UDF and Scheme Programming 1 January 4, 2011 22:45
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 16:13
UDF for square wave velocity profile..pls help Frederik FLUENT 0 May 8, 2006 07:48
