UDF-How to calculate gradient of a scalar
Like Tree27Likes
  • 2 Post By Tony Tonton
  • 4 Post By Graham Goldin
  • 1 Post By Ilkay Sensoy
  • 1 Post By Greg Perkins
  • 1 Post By n.phililipova
  • 1 Post By wond
  • 5 Post By billwangard
  • 1 Post By wond
  • 1 Post By billwangard
  • 2 Post By n.phililipova
  • 1 Post By Azy
  • 1 Post By syavash
  • 1 Post By Azy
  • 1 Post By mvee
  • 1 Post By Maryam-A
Old   February 18, 2000, 14:33
Default UDF-How to calculate gradient of a scalar
Tony Tonton
Hi! I am trying to write a UDF for fluent. I need to calculate the gradient of a scalar. Does anybody have any idea how can I do that. That is, what are the macros available in Fluent that I can usse to calculate the gradient? Thanking you in advance Tony
Svetlana and adarshvasa like this.
Old   February 20, 2000, 16:44
Default Re: UDF-How to calculate gradient of a scalar
Graham Goldin
Fluent will store the gradient of all User Defined Scalars. So, enable a scalar in the Define -> Models -> User Defined Scalars panel, and turn off it's solution in the Solve -> Controls panel. Then, in your UDF, copy the scalar that you want (say temperature) into the User Defined Scalar ( C_UDSI(c,t,0) ), and you can use it's gradient ( C_UDSI(c,t,0)[i], where i=0,1 and 2 in 3D).
Old   February 22, 2000, 17:24
Ilkay Sensoy
Hi Everbody I would like to thank Graham very much for his reply. On the other hand, I will need more help on this. I am trying to get the gradient of a scalar that I get by using UDS in Fluent. That is, I want to use the gradient of C_UDSI(c,t,0) in my UDF code. Is C_UDSI_G(c,t,0) will give me the gradient of C_UDSI(c,t,0)?
If that is correct why in my UDF the gradient returns no value?
Thanking you in advance Regards
Svetlana likes this.
Old   February 22, 2000, 20:09
Ilkay Sensoy
Hi Everybody, I post a message concerning the calculation of a gradient of a scalar. I would like to share more information on that. There is a sample program in Fluent files. It calculates the magnitude of the gradient of T^4.I have tried to compile that code. But,the code did not generate an executable file. So there is something missing. I think I need to do something in fluent to make that code to work but I do not know what. I will aprciate your help Thanking you in advance Ilkay
Old   February 24, 2000, 02:51
Greg Perkins
Graham,
Thanks for your suggestions.
Is it necessary to copy the scalar to a UDS as you suggest in order to determine the gradient??
For example, for temperature can one access the gradient through the macro:
C_T_G(cell,thread)[x], where x = 0, 1, 2 for the spatial direction
I notice that in mem.h, C_DUDX (which calculates the gradient of the velocity component U in the x-direction) and others are actually defined as:-
C_U_G(cell,thread)[0] etc.
Also, how do you determine the temporal gradient of a scalar in transient calculations? In particular if I have a UDS how do I get access to the transient term, to add as a source term to one of the other transport equations???
Thanks
Regards
Greg Perkins
Old   July 7, 2013, 07:42
Default UDF- How to retrieve WSS from Fluent and calculate temporal and spatial gradients?
Nina Philipova
n.phililipova is on a distinguished road
How to retrieve WSS from Fluent and calculate temporal and spatial gradients in UDF?
n.phililipova is offline   Reply With Quote
Old   July 14, 2013, 06:03
wond is on a distinguished road
Hi,Greg Perkins,
Implemented of the source term is a way, but there may be a convergence problem.
I'm not sure if i understand U, but, in my opinion,the DEFINE_UDS_UNSTEADY udf is a good reference.
Wond
wond is offline   Reply With Quote
Old   July 16, 2013, 13:37
Default How to calculate UDS gradient
Bill Wangard
billwangard is on a distinguished road
The following code should poplulate the UDS gradient variable:
#include "udf.h"
#include "sg.h"
DEFINE_ADJUST(adjust,d)
   int n;
   for(n=0; n<n_uds; ++n) uds_derivatives(d, n);
   /* The UDS gradients are now available */
void uds_derivatives(Domain *d, int n)
   /* Code to compute derivative of a variable.  Variable storage allocation first.... */
        MD_Alloc_Storage_Vars(d, SV_UDSI_RG(n), SV_UDSI_G(n), SV_NULL);
        Scalar_Reconstruction(d, SV_UDS_I(n), -1, SV_UDSI_RG(n), NULL);
        Scalar_Derivatives(d, SV_UDS_I(n), -1, SV_UDSI_G(n), SV_UDSI_RG(n), NULL);
        return;
Then, in your UDF, you can access the gradient with C_UDSI_G(c,t). Remember, this is a vector quantity.
blackmask, wond, Svetlana and 2 others like this.
billwangard is offline   Reply With Quote
Old   July 17, 2013, 02:16
#include "udf.h"
#include "sg.h"
   int n;
        return;
Hi, Bill,
As we know, The ANSYS FLUENT (V.13 or higher) have the couple level-set option. Do you have any idea to export the level-set function by udf?
Thanks a lot!
Wond
Old   July 17, 2013, 05:03
Default UDS Gradient variable
Nina Philipova
A would like to thank you so much to Bill Wangard for his immediate reply and for his help!
Wish you great further successes!
Nina Philipova
Old   July 17, 2013, 19:50
Bill Wangard
Regarding coupled level-sets, I don't have any information for you. Sorry.
Old   July 20, 2013, 09:00
Default Calculating WSS components and their derivatives
  #12
Nina Philipova
I found a code, that calculate WSS as a magnitude of viscous fources vector. Area vector is given also as a magnitude of a vector.
I need to calculate components of WSS and their gradients, I don't need a magnitude of vector.
Can someone help with advise, please!
#include "udf.h"
DEFINE_ON_DEMAND(wall_shear_calc)
Domain *d;
real wall_shear_force, area;
face_t f;
real A[ND_ND];
cell_t c, c0;
Thread *t,*t0, *c_thread;
int Zone_ID=6; /* Zone ID of the wall on which shear stress has to be calculated */
/* It can be obtained from the boundary condition panel.*/
d=Get_Domain(1);
/* Initialize the UDM value to zero in complete domain */
thread_loop_c(c_thread,d)
begin_c_loop(c, c_thread)
C_UDMI(c,c_thread,0)= 0;
end_c_loop(c, c_thread)
/* Calculate wall shear stress and store them in UDM */
t=Lookup_Thread(d,Zone_ID);
begin_f_loop(f, t)
F_AREA(A,f,t);
area = NV_MAG(A);
wall_shear_force = NV_MAG(F_STORAGE_R_N3V(f,t, SV_WALL_SHEAR));
c0 = F_C0(f,t);
t0 = THREAD_T0(t);
C_UDMI(c0,t0,0)= wall_shear_force/area;
end_f_loop(f, t)
weilin and Svetlana like this.
Old   July 22, 2013, 04:28
Default How to Calculate WSS Spatial and Temporal Gradients
  #13
Nina Philipova
Please, exuse my misunderstanding!
If I correctly understood, I must retrieve calculated by Fluent Wall Shear Stress not to caculated them again. I am not sure that the available gradients and the stored variable are exactly WSS In code of Bill Wangard. Excuse me for that. I have just a small atempt in UDF. How can I assign exactly x-, y-, z-derivatives of WSS components and to calculate WSS temporal or spatial gradient.
Old   July 16, 2014, 16:19
Smile
  #14
Azy
Azadeh Saeedi
Azy is on a distinguished road
does anybody here know that how to calculate velocity gradient over tracked particles?
Azy is offline   Reply With Quote
Old   July 18, 2014, 19:56
Ehsan Asgari
syavash is on a distinguished road
Isn't it possible to identify the cell at which particle is present at a specific moment?! If yes, I think it would be a good approximation to use velocity gradient of the cell instead of the particle.
Bests.
syavash is offline   Reply With Quote
Old   July 18, 2014, 21:34
Azy
Azadeh Saeedi
Originally Posted by syavash View Post
Bests.
your suggestion is really wise, I have to think about it, and also try it.
Thanks alot
Old   February 9, 2015, 02:12
Default UDS gradient
  #17
Vaze
mvee is on a distinguished road
Hi Bill
I found your code of gradient is not working.
Have you checked at your end?
Can you please tell me the procedure?
Thank you
mvee is offline   Reply With Quote
Old   September 21, 2015, 10:13
Maryam-A is on a distinguished road
Thanks for all posts.
Maryam-A is offline   Reply With Quote
Old   October 6, 2020, 05:43
a_dejong is on a distinguished road
Hi mvee
With Bill's code my gradients were all 0. I found that using Alloc_Storage_Vars instead of Md_Alloc made it work.
a_dejong is offline   Reply With Quote
Old   November 20, 2023, 09:13
anonymous96
anonymous96_ is on a distinguished road
Hi
I am also getting my gradients involved term zero and I tried the above code both ways and none is working for me. Can you please help me?
anonymous96_ is offline   Reply With Quote
Wall shear stress gradient udf Andrew FLUENT 3 April 4, 2018 02:36
How to calculate the gradient along the boundaries from a known volScalarFiled? shddx1 OpenFOAM Programming & Development 7 March 16, 2017 11:47
how to calculate scalar data at a particular plane premchand Siemens 4 May 27, 2008 11:32
Calculated gradient boundary condition similar to gammaContactAngle adona058 OpenFOAM Running, Solving & CFD 0 September 26, 2007 16:23
Gradient of Scalar calculation in 3D BFCskew grids james T Phoenics 0 March 28, 2007 08:12
