Parabolice velocity profile for multiple inlet structure |
November 29, 2023, 06:26 |
seo
Hello, I am new to FLUENT and currently working on fluid simulation with the model consists of multiple inlets and outlets.
I'm trying to apply parabolic velocity profile of a laminar flow using the below UDF code and keep failing it. ----------------------------------------------------------------------- #include "udf.h" #include <math.h> DEFINE_PROFILE(parabolic_flow,t,i) /* t = therad, i = position */ { real x[3]; real r, Umax; real Umean = 150; real R =0.3; face_t f; Umax = 2 * Umean; r = sqrt(pow(x[0],2)+pow(x[1],2)+pow(x[2],2)); begin_f_loop(f,t) { F_CENTROID(x,f,t); F_PROFILE(f,t,i) = Umax * (1 - (pow(r,2)/pow(R,2))); } end_f_loop(f,t) } -------------------------------------------------------------------------- please look through the code and any help will be appreciated. Thank you in advance |
November 29, 2023, 19:33 |
Alexander
Rep Power: 34 |
best regards ****************************** press LIKE if this message was helpful |
December 2, 2023, 06:02 |
seo
Thank you for the reply
Now I'm testing the code with a simple cylinder structure but keep getting the velocity contour as below, literally similar to the flat velocity profile rather than parabolic velocity profile.. (I've used low enough velocity to apply laminar flow ) I believe if I apply parabolic velocity profile, contour inside the cylinder should be red in the middle and gradually become blue as it reaches the boundary layer unlike the figure below. would this be the problem resulted due to the code or any setting that I'm using for the simulation? |
laminar flow, parabolic inlet, udf code |
combining parabolic inlet velocity profile with time varying velocity vector values | jawapasu | OpenFOAM | 3 | July 10, 2023 05:41 |
UDF - Inlet Velocity Profile (Ansys Fluent) | vinayak4399 | Fluent UDF and Scheme Programming | 3 | August 25, 2020 14:15 |
Velocity inlet BC profile | antonio.c | FLUENT | 1 | November 1, 2017 14:22 |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 06:25 |
Export & Import Velocity profile as Inlet | eRzBeNgEl | STAR-CCM+ | 6 | March 26, 2012 05:16 |
