Reading a udf variable value in TUI
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 2, 2023, 11:38
Question Reading a udf variable value in TUI
Nick
valahian1 is on a distinguished road
Hi there!
I'm trying to get the value of a variable from UDF in TUI. For this, I defined the variable in TUI:
(rp-var-define 'test_demand 0 'real #f)
I also initialized the domain with temperature = 300 K
I compiled the UDF:
#include "udf.h"
DEFINE_ON_DEMAND(demand_test)
Domain *d;
real tx = 1;
Thread *t;
cell_t c;
d = Get_Domain(1);
thread_loop_c(t,d)
begin_c_loop(c,t)
tx = C_T(c,t); /* get cell temperature */
end_c_loop(c,t)
Message ("Test demand = %f\n",tx);
RP_Set_Real("test_demand",tx);
Using rpgetvar, I expect to receive the value 300, as the message also displays:
Test demand = 1.000000
Test demand = 300.000000
Instead, I receive the value of 1, with which the tx variable was set at the beginning of the code:
> (rpgetvar 'test_demand)
1
Can you tell me where I am wrong? How could I get the current value of the tx variable?
Thanx!
valahian1 is offline   Reply With Quote
Old   January 19, 2023, 04:10
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
(%rpgetvar 'test_demand)
you will recieve updated value of tx variable
howver, tx would contain the temperature value of the LAST cell in the loop
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   January 21, 2023, 08:54
Nick
Originally Posted by AlexanderZ View Post
Hello Alexander and thank you for your response!
I still get the same value, even using %rpgetvar:
test_demand
;; Execute Define_on_demand, after the domain was initialized
Test demand = 325.000000
;; Try to get the variable's value
1
I know that tx would contain the temperature value of the last cell in the loop (the entire domain was initialized with 325 K), but I'm testing the intercommunication between Fluent macros and Scheme.
Old   February 4, 2023, 11:55
Alexander
you should send rpvar from host
that could be a problem
read ansys fluent customization manual to check how to define rpvar in scheme code in other way
valahian1 likes this.
best regards
Old   February 5, 2023, 08:41
Nick
Thank you, Alexander!
exchange variable, scheme, tui, udf
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 07:37
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 05:35
UDF reading species data of pdf simulations Jamiro FLUENT 0 June 20, 2001 18:15
