Writing DO intensity into file with parallel architecture using UDF |
December 16, 2022, 05:59 |
Kuljeet Singh
Rep Power: 4 |
hi
i am using this UDF to write DO intensity into a file. the case is square cavity with wall at 0K and CO2 at 1000K inside). When i am writing for individual face, i am getting right values its not happening for the whole wall, i am using a coarse grid just to check that. can anyone look into it. I think the problem is with parallel architecture i.e., have 1 host and 1 node process. -K Link for case file, UDF and generated files for both case. "https://drive.google.com/file/d/1dItCD05Y9APaoA-AWt6RsqSvFhg5YUMd/view?usp=share_link" |
December 16, 2022, 08:20 |
Alexander
Rep Power: 34 |
share your code, explain problems
best regards ****************************** press LIKE if this message was helpful |
December 17, 2022, 05:40 |
UDF to write Intensity. i have shared with above google drive link.
Kuljeet Singh
Rep Power: 4 |
#include "udf.h"
# define FLUID_ID 2 DEFINE_ON_DEMAND(intensity_to_file) { /* Different variables are needed on different nodes */ #if !RP_HOST Domain *domain=Get_Domain(1); Thread *thread; face_t f; cell_t c; int k; #else int i; #endif #if !RP_NODE FILE *fp = NULL; char filename[]="intensity12.txt"; #endif int size; /* data passing variables */ real *array; int pe; #if !RP_HOST thread=Lookup_Thread(domain,8); // bottom wall id =8; #endif #if !RP_NODE if ((fp = fopen(filename, "w"))==NULL) Message("\n Warning: Unable to open %s for writing\n",filename); else Message("\nWriting intensity to %s...",filename); #endif /* UDF Now does 2 different things depending on NODE or HOST */ #if RP_NODE /* Each Node loads up its data passing array */ size=THREAD_N_ELEMENTS_INT(thread)*4*1*1; array = (real *)malloc(size * sizeof(real)); //for (int l=0;l<10;l++)/////////////////////////////////writing //{ begin_f_loop_int(f,thread) //f is from 0 to 9 for(k=0;k<4;k++) ////////////k is no of angualr discritised grid points = phi*theta*4(2D case) { array[k*(l+1)]= C_DO_I(l,thread,k); Message("%f\n",array[k*(l+1)]); //printf("%lf",array[k]); //array[k]= F_DO_I(9,thread,k); } end_f_loop_int(f,thread) /* Set pe to destination node */ /* If on node_0 send data to host */ /* Else send to node_0 because */ /* compute nodes connect to node_0 & node_0 to host */ pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero; PRF_CSEND_INT(pe, &size, 1, myid); PRF_CSEND_REAL(pe, array, size, myid); free(array);/* free array on nodes after data sent */ /* node_0 now collect data sent by other compute nodes */ /* and sends it straight on to the host */ if (I_AM_NODE_ZERO_P) compute_node_loop_not_zero (pe) { PRF_CRECV_INT(pe, &size, 1, pe); array = (real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(pe, array, size, pe); PRF_CSEND_INT(node_host, &size, 1, myid); PRF_CSEND_REAL(node_host, array, size, myid); free((char *)array); } #endif /* RP_NODE */ #if RP_HOST compute_node_loop (pe) /* only acts as a counter in this loop */ { /* Receive data sent by each node and write it out to the file */ PRF_CRECV_INT(node_zero, &size, 1, node_zero); array = (real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(node_zero, array, size, node_zero); //for (i=0; i<8; i++) for (i=0; i<size; i++) fprintf(fp, "%g\n", array[i]); free(array); } #endif /* RP_HOST */ #if !RP_NODE fclose(fp); Message("Done\n"); #endif } |
December 26, 2022, 04:06 |
Alexander
Rep Power: 34 |
try this code, compile
#include "udf.h" # define FLUID_ID 2 DEFINE_ON_DEMAND(intensity_to_file) { /* Different variables are needed on different nodes */ Domain *domain; Thread *thread; face_t f; cell_t c; int i,k; FILE *fp = NULL; char filename[]="intensity12.txt"; int size; /* data passing variables */ real *array; domain=Get_Domain(1); thread=Lookup_Thread(domain,8); // bottom wall id =8; #if !RP_NODE if ((fp = fopen(filename, "w"))==NULL) Message("\n Warning: Unable to open %s for writing\n",filename); else Message("\nWriting intensity to %s...",filename); #endif #if RP_NODE size=THREAD_N_ELEMENTS_INT(thread)*4*1*1; array = (real *)malloc(size * sizeof(real)); begin_f_loop_int(f,thread) /*f is from 0 to 9*/ { for(k=0;k<4;k++) /*k is no of angualr discritised grid points = phi*theta*4(2D case)*/ { array[k*(f+1)]= C_DO_I(f,thread,k); Message0("%f\n",array[k*(f+1)]); } } end_f_loop_int(f,thread) #endif node_to_host_int_1(size); node_to_host_real(array,size); #if !RP_NODE for (i=0; i<size; i++) fprintf(fp, "%g\n", array[i]); free(array); fclose(fp); #endif Message0("Done\n"); }
December 26, 2022, 04:42 |
showing error
Kuljeet Singh
Rep Power: 4 |
Thanks for replying, but this code is not compiling. It is showing error mentioned below. I think we cant write to a file without using parallel architect.
ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). The system cannot find the file specified -K |
December 26, 2022, 06:02 |
Alexander
Rep Power: 34 |
press build, not load
December 26, 2022, 06:07 |
Kuljeet Singh
Rep Power: 4 |
But how will i execute it. If i just load code, it is not showing in "execute on demand". So its not writing into anything.
December 27, 2022, 03:07 |
Alexander
Rep Power: 34 |
google "how to compile code in fluent"
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 03:36 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 07:47 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
