Build & Complied with Warnings UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 7, 2022, 05:51
Default Build & Complied with Warnings UDF
Shuttle
Shuttle is on a distinguished road
I have a very basic UDF for dynamic viscosity:
#include "udf.h"
DEFINE_PROPERTY(cell_viscosity,c,t)
real mu_lam;
real temp = C_T(c,t);
if (temp > 362.)
mu_lam = 5.53e-3;
else if (temp > 333.)
mu_lam = 760*exp(-0.0322*temp);
else
mu_lam = 1.662e-2;
return mu_lam;
But I am getting the following warnings. I have no knowledge about C, as It already complied, should I ignore the warnings?
C:\PROGRA~1\ANSYSI~1\v202\fluent\ntbin\clang\kit\i nclude\shared\basetsd.h(317,12): warning: cast to 'void * __ptr32' from smaller integer type 'unsigned long' [-Wint-to-void-pointer-cast]
return((void * POINTER_32) (unsigned long) (ULONG_PTR) p);
In file included from TemperatureProfile.c:6:
In file included from C:\PROGRA~1\ANSYSI~1\v202\fluent\fluent20.2.0\src\ udf\udf.h:22:
In file included from C:\PROGRA~1\ANSYSI~1\v202\fluent\fluent20.2.0\src\ main\global.h:251:
C:\PROGRA~1\ANSYSI~1\v202\fluent\fluent20.2.0\cort ex\src\cx.h(167,5): warning: incompatible redeclaration of library function 'strncasecmp' [-Wincompatible-library-redeclaration]
int strncasecmp (const char *, const char *, int);
C:\PROGRA~1\ANSYSI~1\v202\fluent\fluent20.2.0\cort ex\src\cx.h(167,5): note: 'strncasecmp' is a builtin with type 'int (const char *, const char *, unsigned long long)'
2 warnings generated.
Thank you!
Shuttle is offline   Reply With Quote
Old   December 8, 2022, 00:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may ignore these warnings. looks like they are related to fluent system files and compiler version.
Shuttle likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
SU2 3.0 build failure waku2005 SU2 Installation 4 January 24, 2014 13:40
complied udf in the fluent tranvantrung551987 ANSYS 0 August 23, 2013 00:17
UDF -BUILD chakradhar FLUENT 2 March 28, 2007 16:15
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
