Is there any example of UDF available regarding this formula for near wall correction |
September 3, 2022, 12:29 |
Shuvo Chowdhury
Rep Power: 4 |
Hello. I have to add this near wall correction for modeling turbulence with RSM model.
I don't find any example of adding this with UDF. Can you suggest me anything regarding this? vrms u∗ = C(y+)2, for y+ < 4 |
September 6, 2022, 03:22 |
Alexander
Rep Power: 34 |
probably you may use DEFINE_PROFILE to recalculate veolcity
look for c0 and t0 in ansys fluent customization manual to get cell/thread of cell adjusted to boundary
best regards ****************************** press LIKE if this message was helpful |
September 9, 2022, 18:25 |
Shuvo Chowdhury
Rep Power: 4 |
Hello. Thanks for your reply.
This velocity is wall normal fluctuation velocity. How I can re calculate this and where to input this UDF ? Please let me know. I am stuck at this problem for many days and can't progress. Capture.JPG The figure above is the equation that I need to implement. C is a constant. v_rms is the fluctuation velocity in wall normal direction. ( I thought this could be done as Reynolds vv source term, but not being able to write the UDF ) |
[snappyHexMesh] How to draw a 3D-Drawing for Meshing | Kahnbein.Kai | OpenFOAM Meshing & Mesh Conversion | 4 | June 15, 2021 13:16 |
Ansys CFD-Post Application Error | rushiCFD | FLUENT | 0 | March 21, 2021 08:51 |
How to use a UDF to set the volume fraction in the cells next to a wall? | DF15 | Fluent UDF and Scheme Programming | 33 | August 20, 2020 14:36 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
