Have trouble that the updated UDF variables can't transfer to TUI scheme files |
July 21, 2022, 22:31 |
Heisenberg Geehrte
Rep Power: 4 |
The post starter wanted to use TUI command to switch boundary condition type when the outlet pressure reach the critical point(10000Pa). The UDF and TUI commands are being used in this case.
Here is my idea in handling this. I defined a variable "outlet_pressure" in scheme file and then it's called in UDF by "RP_GET_Real" command. In UDF I computed the average pressure on outlet surface and then update this variable. Finally, by using "rpgetvar", I can access the value of outlet pressure and decide whether to change the outlet boundary condition or not. However, the post starter found that after a few calculation steps, the TUI can't access the updated UDF "outlet_pressure" value. In Fluent console panel I tapped (rpgetvar 'outlet_pressure) command and it returned the initially set value 1. I used EXECUTE_AT_END macro in UDF, here is UDF code: Code:
#include "udf.h" DEFINE_EXECUTE_AT_END(pres_check) /* Average pressure on outlet surface */ { int zone_ID_outlet = 10; real A[ND_ND]; Thread *thread; face_t f; real o_pressure, outlet_pressure; real P_ave = 1.0, P_sum = 0.0, A_sum = 0.0; Domain *d; d = Get_Domain(1); thread = Lookup_Thread(d, zone_ID_outlet); o_pressure = RP_Get_Real("outlet_pressure"); begin_f_loop(f, thread) { F_AREA(A,f,thread); A_sum += NV_MAG(A); P_sum += NV_MAG(A)*F_P(f,thread); } end_f_loop(f, thread) P_ave = P_sum/A_sum; if (P_ave > o_pressure) o_pressure = P_ave; RP_Set_Real("outlet_pressure",o_pressure); printf("Outlet Pressure = %f \n",o_pressure); } Code:
(rp-var-define 'outlet_pressure 1.0 'real #f) (cond ((<= (%rpgetvar 'outlet_pressure) 10000) (ti-menu-load-string "define/boundary-conditions/zone-type 10 wall")) (else (ti-menu-load-string "define/boundary-conditions/zone-type 10 pressure-outlet")) ) |
July 23, 2022, 12:08 |
Rep Power: 12 |
One possibility is that the rp-var-define command is constantly overwriting the value. It is fairly common to make sure that rp-var-define is called only once with something like
(if (not (rp-var-object 'rpvarname))(rp-var-define 'rpvarname 0.0 'real #f)) Really I think that you need to debug the sequence yourself: -- Set outlet_pressure to a large negative value; run pres_check; confirm that outlet_pressure has been updated to a sensible value. -- Check that outlet_pressure still has a sensible value when the Scheme starts and ends. -- Check that the ti-menu-load-string commands do what you intend. -- Check that the Scheme cond command does what you intend. -- etc If every step works, the whole thing will work. If not, and if you can't fix the broken step, you'll have a more specific question. |
July 24, 2022, 04:06 |
Heisenberg Geehrte
Rep Power: 4 |
Hi, Obscureed! I noticed that you are a veteran in this forum and I have learnt a lot from your former posts. Thanks for your advice.
Now I have replaced my rp-var-define command into this to make sure that the rp-var-define macro execute only once. Code:
(define (make-new-rpvar 'outlet_pressure -999.0 'real) (if (not (rp-var-object 'outlet_pressure)) (rp-var-define 'outlet_pressure -999.0 'real #f))) (make-new-rpvar 'outlet_pressure -999.0 'real) Code:
Updating solution at time level N... done. iter continuity x-velocity y-velocity energy k epsilon time/iter 65 9.1066e-03 8.5559e-04 2.0053e-03 9.3002e-08 2.6643e-04 2.2503e-03 0:00:00 5 66 9.5180e-03 1.8930e-03 1.4070e-03 1.3492e-07 2.7044e-04 2.2077e-03 0:00:00 4 67 9.3741e-03 1.3079e-03 3.3517e-03 7.6416e-08 2.7824e-04 2.2561e-03 0:00:00 3 68 9.3179e-03 1.2106e-03 1.6374e-03 7.9531e-08 2.8102e-04 2.1450e-03 0:00:00 2 69 9.2098e-03 1.5034e-03 4.6282e-03 8.4639e-08 2.8510e-04 2.0802e-03 0:00:00 1 70 9.1362e-03 1.0286e-03 1.6592e-03 7.8024e-08 2.9011e-04 2.0498e-03 0:00:00 0 Outlet Pressure = 10261.125977 /file/read-macro "scheme3.scm"Loading ".\.\scheme3.scm" define/boundary-conditions/zone-type 10 wall Zone not slit.Done. Updating solution at time level N... done. iter continuity x-velocity y-velocity energy k epsilon time/iter 70 9.1362e-03 1.0286e-03 1.6592e-03 7.8024e-08 2.9011e-04 2.0498e-03 0:00:00 5 71 9.5955e-03 1.0906e-03 3.6865e-03 1.6078e-07 2.9754e-04 2.1202e-03 0:00:00 4 72 9.5147e-03 3.4935e-03 6.3283e-03 7.0936e-08 3.0514e-04 2.1359e-03 0:00:00 3 73 9.4124e-03 1.8094e-03 5.3499e-03 8.1904e-08 3.0944e-04 2.0748e-03 0:00:00 2 74 9.3880e-03 1.5320e-03 4.6221e-03 7.7788e-08 3.1366e-04 1.9670e-03 0:00:00 1 75 9.2679e-03 2.0402e-03 1.1904e-03 7.5247e-08 3.1794e-04 1.9048e-03 0:00:00 0 Outlet Pressure = 10719.134766 /file/read-macro "scheme3.scm"Loading ".\.\scheme3.scm" define/boundary-conditions/zone-type 10 wall Zone not slit.Done. Code:
(rpgetvar 'outlet_pressure) -999 |
August 16, 2022, 11:43 |
Heisenberg Geehrte
Rep Power: 4 |
I have tried a lot of times these days, but I can't get it through. Is there anyone could help me? Thanks a lot!
August 18, 2022, 02:01 |
Alexander
Rep Power: 34 |
if you are using fluent version v19 and earlier, code should be parallelized
so for your case command RP_Set_Real("outlet_pressure",o_pressure); should be executed on host compile following code Code:
#include "udf.h" DEFINE_EXECUTE_AT_END(pres_check) /* Average pressure on outlet surface */ { int zone_ID_outlet = 10; real A[ND_ND]; Thread *thread; face_t f; real o_pressure, outlet_pressure; real P_ave = 1.0, P_sum = 0.0, A_sum = 0.0; Domain *d; d = Get_Domain(1); thread = Lookup_Thread(d, zone_ID_outlet); #if !RP_NODE o_pressure = RP_Get_Real("outlet_pressure"); #endif host_to_node_real_1(o_pressure); Message0("o_pressure on node from scheme = %f \n",o_pressure); begin_f_loop(f, thread) { F_AREA(A,f,thread); A_sum += NV_MAG(A); P_sum += NV_MAG(A)*F_P(f,thread); } end_f_loop(f, thread) P_ave = P_sum/A_sum; if (P_ave > o_pressure) o_pressure = P_ave; Message0("Outlet Pressure on node = %f \n",o_pressure); node_to_host_real_1(o_pressure); #if !RP_NODE RP_Set_Real("outlet_pressure",o_pressure); Message("Outlet Pressure on host = %f \n",o_pressure); #endif } scheme Code:
(define (make-new-rpvar name default type)(if (not (rp-var-object name))(rp-var-define name default type #f))) (make-new-rpvar 'outlet_pressure 1.0 'real) (cond ((<= (%rpgetvar 'outlet_pressure) 10000) (ti-menu-load-string "define/boundary-conditions/zone-type 10 wall")) (else (ti-menu-load-string "define/boundary-conditions/zone-type 10 pressure-outlet")) )
best regards ****************************** press LIKE if this message was helpful |
August 19, 2022, 05:41 |
Heisenberg Geehrte
Rep Power: 4 |
Thank you so much, Master AlexanderZ. Since I tried your modified codes in parallel, an connection between UDF and TUI was established!
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Call FORTRAN files as UDF in a Linux system | azores | Fluent UDF and Scheme Programming | 6 | October 21, 2022 16:53 |
Mass transfer UDF expecting void return | Quinos | Fluent UDF and Scheme Programming | 0 | January 8, 2014 19:36 |
OpenFOAM15 paraFoam bug | koen | OpenFOAM Bugs | 19 | June 30, 2009 11:46 |
[making animations] fclose fails to close files? | Mika | FLUENT | 0 | March 30, 2001 09:19 |
