how to save parameter in each time step without deleting pervious time step data
Like Tree3Likes
  • 1 Post By jps115
  • 1 Post By jps115
  • 1 Post By shedo
Old   April 8, 2022, 18:35
Default how to save parameter in each time step without deleting pervious time step data
sheida
shedo is on a distinguished road
hello experts,
I want to save and write one of my defined parameters in a file in each time step without deleting the previous steps' data because I want to compare this parameter in each step. Can anyone help me to know how to save this data by UDF?
shedo is offline   Reply With Quote
Old   April 9, 2022, 08:30
Jeroen de Graaff
jps115 is on a distinguished road
Hey shedo,
You could look into DEFINE_RW_FILE, to write your defined parameter to a file and read the parameter back. This way the data is stored and you can access it.
See for more information:
https://www.afs.enea.it/project/nept...udf/node29.htm
I hope this was usefull!
shedo likes this.
jps115 is offline   Reply With Quote
Old   April 10, 2022, 03:00
sheida
Dear Jeroen,
thanks for your response. I would like to know whether it is capable of recognizing and recalling the previous step data or not?
Old   April 10, 2022, 04:40
Jeroen de Graaff
Do you want to use the value for post-processing or for it to be used for later calculations within your simulation?
For post-processing, you can write both the time step and your defined parameter to the file with the macro CURRENT_TIMESTEP. To use it within your simulation you can use another DEFINE_RW_FILE function to read back the data.
shedo likes this.
Old   April 10, 2022, 05:23
sheida
Dear Jeroen,
I want to use it within simulation.
your explanation was useful, I do appreciate you.
jps115 likes this.
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
