Non-equilibrium model in porous media
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   April 5, 2022, 14:42
Post Non-equilibrium model in porous media
Masoud Ahmadi
ahmadimasoud is on a distinguished road
Hello all,
I am trying to simulate a water vapor adsorption process by a solid desiccant in Fluent 2021 R1.
The geometry is a simple 2-D channel. It has one entrance region (non-porous) and one exit region (non-porous) and the porous domain of solid desiccant between them.
As you know, Fluent creates a new solid zone when the non-equilibrium model is activated.
Now, my question is:
For setting a source term in the species transport equation of the fluid region of the porous domain, I need to have access to the solid zone temperature. But since the UDF for the source term is hooked to the fluid region, it just loops in the threads which are for the fluid region and I do not know how to access the temperature of the solid threads (T=C_T(c,t) is the fluid temperature and not the solid temperature).
I appreciate it if you could help me find the solution.
ahmadimasoud is offline   Reply With Quote
Old   April 5, 2022, 23:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
as you told new solid zone is created, so It must have thread ID, you may try to access solid zone by its ID
ahmadimasoud and jadidi.cfd like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   April 6, 2022, 11:45
Masoud Ahmadi
Thank you for your reply.
The problem is: when the source term is hooked to the fluid region of the domain it just have the "fluid region" thread ID and when I try to access other threads, it shows and error and close Fluent.
Old   June 16, 2022, 03:50
Hasan Najafi Khaboshan
Hasan_Najafi is on a distinguished road
Since you have source term UDF, I guess you can access to the solid threads as AlexanderZ said.
I have a question here, when you generated the solid zone, what did you do with the boundary of your solid zone. In my case, I have rectangular fluid and solid (porous) zone in the center and all four edge of them covered by solid zones. There is interface boundary betwen fluid zone in the center and solid zone around it. But, when the solid zone of porous is created by fluent, it has own boundaries. So, what boundary type should I chose for them?
Thanks
Hasan_Najafi is offline   Reply With Quote
Old   April 14, 2023, 19:07
Default Same issue
Mohammad
Selawe97 is on a distinguished road
Thanks
I am also facing the same issue, I don't know which wall I should apply the boundary condition, for example, heat flux, should I apply it to the fluid wall or to the new solid wall, did you solve it?
thanks
Selawe97 is offline   Reply With Quote
Old   April 16, 2023, 22:59
thanks
Hi, after validating my problem with experimental work, I realized that I should keep it as it was. I mean we do not have to select a specific boundary for that, because Ansys Fluent use this solid zone as a place to save the data for the solid zone (metal foam zone), and these two zones are connected with heat transfer which is located in two-equation local non-equilibrium thermal model. This is how I think it works.
Porous Media Zone Thickness TheKitchenCleaner FLUENT 0 October 5, 2020 01:42
Porous Media Model reaction mechanism umairjamil FLUENT 1 July 2, 2016 09:23
local thermal non equilibrium model in porous media adi.ptb Fluent UDF and Scheme Programming 0 November 1, 2014 16:00
How do model two phase granular flow in Porous media? bahman FLUENT 1 December 6, 2012 05:39
How to Model Porous media in CFX senCFX Main CFD Forum 0 January 10, 2011 11:02
