i have a problem with my udf when I give it Run Calculation
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   April 1, 2022, 17:50
Default i have a problem with my udf when I give it Run Calculation
Sergio Andres Correa Zea
secorreaz is on a distinguished road
Hello good afternoon everyone
When I mount my UDF code there is no problem but when I press the Run Calculation option during the initialization it shows me this error and then it ejects me from Ansys
"999999: mpt_accept: error: accept failed: No error".
The fl process could not be started
Attached is my code
Thank you very much
PHP Code:
#include "udf.h"
#include "sg_mphase.h"
#include "mem.h"
#include "sg_mem.h"
#include "flow.h"
#include "unsteady.h"
#include "metric.h"
#include "math.h"
enum
ads,
q_ads,
d_ads
/* UDF el cual se realizara es el de              */
/* Dubinin Astakov para poder mostrar el fenomeno */
/* de adsorciأ³n                                   */
DEFINE_ADJUST(define_ads,domain)
#if !RP_HOST
Thread *t;
real E,A,P;
cell_t c;
real tem;
thread_loop_c(t,domain)
begin_c_loop(c,t)
tem C_T(c,t);
P=C_P(c,t)+RP_Get_Real("operating-pressure");
E=3080.0+18.9*tem;
A=8.314*tem*log(1.47e9/P);
C_UDSI(c,t,0) = 71.6*(exp(-((A*A) / (E*E))));
end_c_loop(c,t)
#endif
/* El siguiente codigo permitira implementar el LDF
/*   este presentara 3 cأ³digos distinto el cual albergara
/*   la adsorcion dinamica para cada iteraciأ³n calculada
/*  y almacenada por la ejecuciأ³n de la UDF que esta definida  */
/*  usando DEFINE_ADJUST(q_ads,domain)                         */
DEFINE_ADJUST(define_q_ads,domain)
#if !RP_HOST
Thread *t;
cell_t c;
real dt;
begin_c_loop_int(c,t)
dt=RP_Get_Real("physical-time-step");
C_UDSI(c,t,0)=C_UDSI_M1(c,t,0)+0.15*dt*(C_UDSI_M1(c,t,1)-C_UDSI_M1(c,t,0));
end_c_loop_int(c,t)
#endif
/*   El siguiente código El término de la fuente de masa de cada */
/*   iteración se calcula y almacena ejecutando la UDF que se    */
/*   define con  DEFINE_ADJUST(d_ads, domain)                    */
DEFINE_ADJUST(define_d_adsdomain)
#if !RP_HOST
Thread *t;
cell_t c;
thread_loop_c(tdomain)
C_UDSI(ct0) = -0.532224*0.15*(C_UDSI(ct1) - C_UDSI(ct0));
end_c_loop_int(c,t)
#endif
DEFINE_SOURCE(m_src,c,t,dS,eqn)
dS[eqn]=0.0;
return
C_UDSI_M1(ct0);
secorreaz is offline   Reply With Quote
Old   April 3, 2022, 23:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
what is C_UDSI_M1 macro, how it works?
also you don't need #if !RP_HOST, #endif directives in your code
secorreaz likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
UDF weird problem Sunmax Fluent UDF and Scheme Programming 2 June 26, 2019 22:48
Help with unsteady calculation with source/sink UDF RobV FLUENT 1 November 13, 2016 06:44
Help with unsteady calculation with source/sink UDF RobV Fluent UDF and Scheme Programming 3 March 10, 2016 04:45
UDF hook problem in command line mode. Benlong FLUENT 1 November 12, 2007 15:45
Warning 097- AB Siemens 6 November 15, 2004 05:41
