[ANSYS FLUENT] Ascertain a phase-change to a particular region in interior?
Like Tree1Likes
  • 1 Post By ehsan.bakhtiari
Old   March 13, 2022, 12:57
Default [ANSYS FLUENT] Ascertain a phase-change to a particular region in interior?
ehsan bakhtiari
ehsan.bakhtiari is on a distinguished road
I want to simulate an ice accretion problem over a solid body.
The location at which ice appears and its height are defined via a DEFINE_GRID_MOTION macro.
The mesh displacement (according to the computed ice height) seems fine. However, since some of the regions over the body would address the presence of water over the ice (called Glaze Ice), I have no idea how to apply water presence on the ice and its temperature profile in these corresponding regions.
I tried to activate the VOF multiphase model and define the water as C_VOF(c,t) = 1.0 using a DEFINE_ADJUST macro. Still, I couldn't readily determine target cells in the interior domain perpendicular to the ice profile. Is my approach correct?
Any ideas would greatly be appreciated.
thapaashok likes this.
ehsan.bakhtiari is offline   Reply With Quote
Old   April 28, 2022, 12:16
Ashok Thapa
thapaashok is on a distinguished road
Hi Eshan,
i too am trying to simulate the ice formation from vapor(desublimation) over a solid plate. I was wondering if you have mangaed to find the solution. I am using multiphase VOF method but finding difficulty in adding ice(solid) as the phase in multiphase model.could you please let me know which module do you use? are you using any specific module for simulation of ice formation
i would highly appreciate if you could respond to the thread.
Thanks,
ashok
thapaashok is offline   Reply With Quote
define_adjust macro, fluent, fluent - udf
Unable to patch Cell Registered Region to define phase for multiphase simulation allenpv Fluent Multiphase 1 February 14, 2021 13:19
Phase Change in VOF Evaporation/Condensation Models yoshiurr STAR-CCM+ 3 March 21, 2019 08:12
Material change during phase transformation (FePO4 > LiFePO4) concentration distribut kimsw0103 CFX 0 January 15, 2016 23:05
Simulation of Phase change material (PCM) and nanoparticles together farah Main CFD Forum 0 November 2, 2015 15:30
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
