Species diffusion through a wall
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   January 26, 2022, 12:52
Default Species diffusion through a wall
Joe
CFD27 is on a distinguished road
Hello all,
I want to simulate the diffusion flow of a species through a wall to the other side of the wall. For this purpose, I have already determined the cells adjacent to the wall using a UDF and thus built in source terms from both sides. To make the sources now dependent on the concentration of the species, I want to determine the gradient of the species. For this I found in pressure-based solver after entering the command "(rpsetvar 'species/save-gradients? #t)" into the TUI. As a first step, I tried to determine the gradient and save it in a UDM so that I can use it later for computation. When compiling the UDF the following error occurs: error C2440: '=': 'real *' cannot be converted to 'real. When modifying the UDF to save the mass fraction, no error occurs. Can anyone give me a hint where my error is?
This is my Code for Saving Gradient:
#include "udf.h"
#include "mem.h"
DEFINE_EXECUTE_AT_END(Grad_calc)
	Domain* d;
	Thread* t;
	cell_t c;
	d = Get_Domain(1);
	thread_loop_c(t, d)
		begin_c_loop(c, t)
			C_UDMI(c, t, 1) = C_YI_G(c, t, 0);
		end_c_loop(c,t)
Thanks in advance.
Many Greetings
Joe
CFD27 is offline   Reply With Quote
Old   February 2, 2022, 20:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
gradient is a vector so you have 3 scalar values for 3D problem
to be
C_UDMI(c, t, 1) = C_YI_G(c, t, 0)[0];
C_UDMI(c, t, 2) = C_YI_G(c, t, 0)[1];
C_UDMI(c, t, 3) = C_YI_G(c, t, 0)[2];
CFD27 and DrMaMad like this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   February 3, 2022, 05:10
Joe
Dear Alexander,
Thank you for your reply. I have already been able to fix the problem myself. Your hint that the gradient is a vector was part of it. I converted the gradient to a scalar using the Magnitude macro. After this error was fixed, a memory error occurred, which I fixed by having the solver access the gradient only after checking to see if it was in memory. In addition, I have replaced Execute at End macro with a Define Adjust macro. Thanks for your help.
Many greetings
Joe
how to define diffusion coefficients for every species in the system? Weiqiang Liu FLUENT 7 June 23, 2021 11:03
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Diffusion flux calculation in the wall boundary face of the wall function approach randolph OpenFOAM 1 August 27, 2018 23:02
Anisotropic Species Diffusion Baden FLUENT 6 January 17, 2017 05:06
