UDF to read large file and store it in C_UDMI |
Rep Power: 6 ![]() |
Dear all,
I ran a first simulation on a mesh and i have exported a quantity of interest (QoI) at each cell center of my CFD domain in a ASCII file type. It is thus a very large file (millions of lines): cellNumber, x-coordinate, y-coordinate, z-coordinate, QoI . . . I would like to re-use this result for a second simulation on the same mesh. How can I read the file and store the QoI inside a C_UDMI(c,t) ? I guess the following option is naive Code:
DEFINE_ON_DEMAND(read_QoI) { #if !RP_NODE /* serial or host process */ char line[100]; int index; float f1, f2, f3, f4; int number_cell = 13786084; float *QoI; QoI = (float *)malloc((number_cell -1)*sizeof(float)); FILE* file_r; file_r = fopen("QoI_ascii", "r"); if(file_r==NULL) { Message("\n"); Message("Error opening file \n"); Message(" \n"); } /* Skip one line by reading one line and ignoring */ fgets(line, 100, file_r); while (fscanf(file_r, "%d%f%f%f%f", &index, &f1, &f2, &f3, &f4) > 0) { QoI[index-1] = f4; } fclose(file_r); Domain *d; d = Get_Domain(1); Thread *t; cell_t c; thread_loop_c(t,d) { begin_c_loop(c,t) { int ID = C_ID(c,t); C_UDMI(c,t,0) = QoI[ID-1]; } end_c_loop(c,t) } free(signal); #endif } Thanks in advance ! |
Alexander
Rep Power: 34 ![]() ![]() |
1. you may write profile and later read it without any UDF
2. on the other hand for single core your code should work well in case you are storing the same cell index as C_ID(c,t) macro returns.
best regards ****************************** press LIKE if this message was helpful |
#3 | |
1. Can the profile tool also be used with field data? Or should it be used for surface ? 2. Ok thanks a lot, I'll give a try with a smaller file then! |
udf, udf and programming |
How to read a Value from Text File and store it in Variables | Amirreza_pro | Fluent UDF and Scheme Programming | 5 | April 5, 2024 15:14 |
How to read a Value from Text File and store it in Variables (writing in UDF) | Amirreza_pro | FLUENT | 0 | October 26, 2020 03:50 |
simple UDF doesn't read input from external file. interprets/compiles without errors | ahmad_xjtu | Fluent UDF and Scheme Programming | 5 | March 23, 2018 02:03 |
UDF macro to read the name of the case file | polaritus | Fluent UDF and Scheme Programming | 2 | March 23, 2015 04:59 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
