FLUENT reports an error when re-reading the case containing udf
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 6, 2021, 23:35
Default FLUENT reports an error when re-reading the case containing udf
WB
BW1211 is on a distinguished road
Hello everyone. Recently,I calculate a case with udf, and if I calculate the specified number of steps at a time, there will be no problems in the calculation, but when I read one of the case that was automatically saved and then calculate, fluent will report an error. What is the reason?
Thank you for your reply.
BW1211 is offline   Reply With Quote
Old   December 7, 2021, 06:27
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should store all variables which you are using in UDF
BW1211 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 7, 2021, 07:04
WB
Thank you very much for your answer. But aren't the variables automatically saved in the case and data in the calculation? How do you mean to store all variables used in UDF?
Illegal cell label -1, fluent3DMeshToFoam BenGher OpenFOAM 7 October 10, 2023 01:02
Postprocess: sampleDict works but creates no output folder shock77 OpenFOAM Post-Processing 14 November 15, 2021 09:27
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
reading case and data file of fluent into the clusters joerik FLUENT 0 February 6, 2012 12:42
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
