How to specifically apply heteregoneous reaction UDF only in certain cell zone
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   October 27, 2021, 10:55
Default How to specifically apply heteregoneous reaction UDF only in certain cell zone
fluidizedbed is on a distinguished road
Hello all,
I have prepared and tested a heterogeneous reaction UDF (DEFINE_HET_RXN_RATE) which turned out to be working fine now.
In my mesh, I have 3 separate cell zones (fluid). At the moment the reaction occurs in all these three zones. If I would like to apply the reaction only in one of these three zones (please see the image below) - what should I do for the macro to pinpoint to the right pointer?
Because of the way the heterogeneous reaction applied (phase interaction - independent of the cell zone, unlike the single phase reaction), I cannot also specify that this reaction only apply at the particular cell zone.
image link
I understood that the top level domain is the superdomain. But this seems to refer to the "mixture", not the "cell zone", and in my case the mixture actually exists in all these three cell zones. Do you have any suggestions how to implement this?
Thanks in advance!
fluidizedbed is offline   Reply With Quote
Old   October 28, 2021, 23:02
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to do following
you may check thread ID using thread from the header of function
DEFINE_HET_RXN_RATE(name, c, t, hr, mw, yi, rr, rr_t)
if THREAD_ID(t) == id of you zone
fluidizedbed likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 29, 2021, 11:16
Thank you!
It works quite well in principle. Just stating this here: for others who are interested with this case, the statements of the thread pointers must be placed before the if statement.
However, somehow in the case that I am working the reaction occurs as well outside the cell zone in the direction of the flow - instead of going directly to 0 when the flow goes to the next cell zone. It is like as if there is a numerical diffusion happening for the reaction.
I am still trying to figure out why actually this can occur.
cell zone, multiphase, reaction, udf
Setting cell variable values in a fluid zone using UDF eromon84 Fluent UDF and Scheme Programming 6 March 28, 2021 12:59
Issue with begin_c_loop when more than one cell zone Brian_ Fluent UDF and Scheme Programming 4 March 2, 2018 12:44
[mesh manipulation] refineMesh Error mohsen.boojari OpenFOAM Meshing & Mesh Conversion 3 March 1, 2018 23:07
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
