Compile UDF in Ubuntu
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   October 13, 2021, 04:21
Default Compile UDF in Ubuntu
Cooper24 is on a distinguished road
Can someone please tell me how to compile UDFs in Ubuntu? I had compiled the UDF in windows using Visual Studio and it was working fine but I needed to switch to Ubuntu as my cluster has Ubuntu installed in it. After a very long struggle I was able to run FLUENT on Ubuntu but now when I compile the UDF, it throws error. Any help is much appreciated. Thanks in advance.
Here is the error:
makefile:121: recipe for target 'Source.o' failed
make[3]: *** [Source.o] Error 1
make[3]: Target 'libudf.so' not remade because of errors.
makefile:211: recipe for target 'lnamd64' failed
make[2]: *** [lnamd64] Error 2
makefile:131: recipe for target 'default' failed
make[1]: *** [default] Error 2
p, li { white-space: pre-wrap; }
Cooper24 is offline   Reply With Quote
Old   October 14, 2021, 01:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you should prepare make file to compile on Linux
special folder structure is also required
check ansys fluent customization manual, there is a detailed description
Cooper24 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 14, 2021, 04:39
Thanks for your reply. I was able to compile the UDF. I had created the specific folder structure from an internet source. But the error due to an unseen comment line.
udf-compile, udf-ubuntu
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Compile c99 standard UDF in Cluster darsonli Fluent UDF and Scheme Programming 0 July 7, 2015 03:58
looking for instructions on how to compile an udf in windows OS Srinivasa Rao Fluent UDF and Scheme Programming 2 May 22, 2015 11:00
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 08:26
Fluent doesnÂīt compile UDF on Windows HSeldon FLUENT 4 February 15, 2007 00:01
