UDF for specific heat
Like Tree3Likes
  • 1 Post By pakk
  • 1 Post By AlexanderZ
  • 1 Post By pakk
Old   August 24, 2021, 03:57
Default UDF for specific heat
Gaurav Kumar
gauravkmr is on a distinguished road
Hi all,
I am modelling the supercritical fluids and as the thermophysical properties changes abruptly, I need to write the UDF for the specific heat of the water. I have fitted the curve in a piecewise manner as follows
200 <= T < 385
C_p=(10.57678-0.02301T)/(1+0.00537T-2.05557×〖10〗^(-5) T^2 )
385 <= T < 600
C_p=(0.83318-0.0033T)/(1-0.00319T-1.49076×〖10〗^(-6) T^2 )
Please help me to write the UDF for the same. Parallelize the code if needed as I am using 20 cores processor
Thanks
gauravkmr is offline   Reply With Quote
Old   August 24, 2021, 04:39
pakk will become famous soon enough
Of course we can help you to make this UDF!
Step 1: find a similar UDF in the Fluent Manual.
Step 2: change it so that you think it does what you want.
Step 3: compile it, check for errors.
Step 4: fix errors until it compiles.
Step 5: check if the UDF does what you want.
Which step is giving you problems?
gauravkmr likes this.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
specific heat can be defined through material properties, you don;t need UDF for that
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 24, 2021, 08:55
Gaurav Kumar
I have written the code as you suggested, here is my code:
#include "udf.h"
DEFINE_SPECIFIC_HEAT(my_user_cp, T, Tref, h, yi)
real cp;
if (200 <= T < 385)
cp = 10.57678-0.02301*T/(1+0.00537*T-2.05557*pow(10,-5)*pow(T,2));
else
cp = 0.83318-0.0033*T/(1-0.00319*T-1.49076*pow(10,-6)*pow(T,2));
*h = cp*(T-Tref);
return cp;
But when I check the value of Cp after running the program in C, the value for 385 <= T <600 is not correct while it is correct for other ranges what is wrong please check it.
Thanks and Regards.
Old   August 24, 2021, 15:30
if (200 <= T < 385)
This does not do what you expect it does. Split it in two :
if ((200 <= T) && (T< 385))
Old   August 25, 2021, 04:54
Gaurav Kumar
Thanks, Pakk it works.
fluent - udf, specific heats, udf
Surface Heat Transfer Coefficient driven by a UDF, using coupled wall ryanbezz11 CFD Freelancers 1 March 16, 2018 04:01
Doubt - Variable Heat Flux input - UDF Neethu_N FLUENT 1 December 19, 2017 12:48
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
UDF for heat convection coefficient with fixed surface temperature Boo85 Fluent UDF and Scheme Programming 2 July 10, 2012 19:43
heat flow UDF on coupled surface (wall-shadow wall) Friedmann Fluent UDF and Scheme Programming 0 August 5, 2010 11:25
