July 20, 2021, 16:20 |
Combined Step+Exponential udf
Joel
Hey all,
I am trying to simulate a transient inlet pressure boundary condition that is a step function with an exponential decay using a udf codeIMG_1830.jpg. I am having trying to come up with a udf that best simulates this situation. I have attached an image to show what I am trying to say. The maximum peak pressure is 3000psi and it should settle at a pressure of around 50 psi at the end of the exponential decay. This is what I have so far:- #include "udf.h" DEFINE_PROFILE(unsteady_pressure,thread,position) { face_t f; real ts= CURRENT_TIMESTEP; real i; real flow_time = RP_Get_Real("flow-time"); begin_f_loop(f, thread) { for(i=1;i<50;i++) { if (flow_time > 0 && flow_time < 0.0001) { F_PROFILE(f, thread, position)= 50.0; } else if (flow_time > 0.0001) { F_PROFILE(f, thread, position)=3000*exp(-flow_time); } else if (flow_time==0.0001) { F_PROFILE(f, thread, position)=3000; } } end_f_loop(f, thread) } } Is a for loop the best way to go about this or should I maybe use an array? Thank you in adavnce |
July 20, 2021, 19:26 |
Rep Power: 27 |
Your for loop doesn't do anything... You repeat the same code 50 times, I don't understand what you are trying to achieve with that. Why loop? Why 50 times?
It looks like you can just remove the loop... Some remarks: -the flowtime==0.0001 part is useless, remove it, you don't need it. If flowtime<0.0001 constant else exponential. -your pressure profile equation for the exponential part is wrong. Should be 3000*exp(0.0001-flow_time). -Fluent expects SI units by default. You have the right to use this silly psi unit, but be careful.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 10:10 |
LES, Courant Number, Crash, Sudden | Alhasan | OpenFOAM Running, Solving & CFD | 5 | November 22, 2019 03:05 |
time step continuity problem in VAWT simulation | lpz_michele | OpenFOAM Running, Solving & CFD | 5 | February 22, 2018 20:50 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 08:47 |
calling result of a UDF into current time step | Komon | Fluent UDF and Scheme Programming | 1 | April 1, 2012 20:53 |
