udf used for ash deposition simulation
Like Tree2Likes
  • 2 Post By AlexanderZ
Old   July 14, 2021, 06:48
Default udf used for ash deposition simulation
WB
BW1211 is on a distinguished road
Hello everyone. Recently,I am using the DPM model to simulate the ash deposition in the boiler. I used the critical viscosity model in udf to describe ash deposition process, and the deposition layer was divided into three layers: particle inner layer, sintered layer and molten layer. It is worth noting that when the surface temperature reaches a certain value, the particle layer can transform to a sintered layer and the sintered layer can transform to a molten layer. I want to get the deposition thickness of each layer through simulation.(This is the background)
My problem is that when I use the udf below, the deposition thickness of the sintered layer is negative (UDM3), which is unreasonable.I hope you can help me check the udf (I have checked it many times, but I haven't found the problem). Thank you for your help.
DEFINE_DPM_BC(capture_bounce_bc, p, t, f, f_normal, dim)
real p_loc[ND_ND],p_temperature, p_diameter;
real plocy,pvel;
real A[ND_ND],area,flow,flux;
real viscosity,visc_exponent;
real p_rep_mass,deposit_mass;
Thread *t0;
cell_t c0;
c0=F_C0(f,t);
t0=F_C0_THREAD(f,t);
//Calculate the mass represented by the impacting particle
p_diameter=P_DIAM(p); //Get Particle Diameter from Fluent
p_rep_mass=RR_MASS_FLOW*TIMESTEP_SIZE*(RR_DIAM_MAX-RR_DIAM_MIN)*(RR_SF/p_diameter)*pow((p_diameter/RR_DBAR),RR_SF)*pow(EXP,-1*(pow((p_diameter/RR_DBAR),RR_SF)))/RR_NUM_PARTICLES;
//Determine viscosity of ash particle
p_temperature=P_T(p); //Get particle temperature from fluent
visc_exponent=14788/(p_temperature-T_Shift)-10.931; //Calculate Ash viscosity
viscosity=(p_temperature-T_Shift)*pow(10,visc_exponent); // Finish Viscosity calculation
//Assume deposited mass is inversely proportional to viscosity when particle viscosity is higher than critical viscosity
if(viscosity>critical_viscosity)
deposit_mass=p_rep_mass*critical_viscosity/viscosity;
else
deposit_mass=p_rep_mass;
//Calculate mass deposited per unit face area
F_AREA(A,f,t);
area=NV_MAG(A); //Get face area from fluent
flux=deposit_mass/area;
F_UDMI(f,t,0)+=deposit_mass;
/*C_UDMI(c0,t0,0)=F_UDMI(f,t,0);*/
//Add thickness to slag layer if the face temperature is higher than T_Slag, then kill the particle and return
if(F_T(f,t)>T_Slag)
F_UDMI(f,t,4)+=flux/RHO_Slag;
/*C_UDMI(c0,t0,4)=F_UDMI(f,t,4);*/
return(PATH_ABORT);
//Add thickness to sintered layer if the face temperature is higher than T_Sinter, then kill particle and return
if(F_T(f,t)>T_Sinter)
F_UDMI(f,t,3)+=flux/RHO_Sinter;
/*C_UDMI(c0,t0,3)=F_UDMI(f,t,3);*/
return(PATH_ABORT);
//Add thickness to particulate layer if the surface temperature is lower than T_Sinter, then kill particle and return
F_UDMI(f,t,2)+=flux/RHO_Particulate;
/*C_UDMI(c0,t0,2)=F_UDMI(f,t,2);*/
return(PATH_ABORT);
DEFINE_DPM_INJECTION_INIT(Injection_Init,I)
int i;
real current_time=0;
Thread *t;
Domain *d;
face_t f;
real R_Part,R_Sint,R_Slag, R_Total, L_Part, L_Sint, L_Slag, T_SintSlag_ifc,
T_PartSint_ifc, T_Surface, Delta_L_Sint,
Delta_L_Melt,Y_Sint,Y_Part;
d=Get_Domain(1);
//Check Sintering and Melting
thread_loop_f(t,d)
if(NNULLP(THREAD_STORAGE(t,SV_UDM_I)))
begin_f_loop(f,t);
L_Part=F_UDMI(f,t,2);
L_Sint=F_UDMI(f,t,3);
L_Slag=F_UDMI(f,t,4);
R_Part=L_Part/K_Particulate;
R_Sint=L_Sint/K_Sinter;
R_Slag=L_Slag/K_Slag;
R_Total=R_Part+R_Sint+R_Slag+R_BASE;
T_Surface=F_T(f,t);
cell_t c0;
Thread *t0;
c0=F_C0(f,t);
//Calculate interface temperatures between ash layers
T_PartSint_ifc=T_Cool+(T_Surface-T_Cool)*(R_Part+R_BASE)/R_Total;
T_SintSlag_ifc=T_Cool+(T_Surface-T_Cool)*(R_BASE+R_Part+R_Sint)/R_Total;
//Ckeck Melting and melt appropriate amount of sintered layer
if(T_SintSlag_ifc>T_Slag)
Y_Sint=R_Total*K_Sinter*(T_Slag-T_Cool)/(T_Surface-T_Cool)-K_Sinter*(R_Part+R_BASE);
Delta_L_Melt=L_Sint-Y_Sint;
F_UDMI(f,t,3)=Y_Sint;
F_UDMI(f,t,4)=L_Slag+Delta_L_Melt*RHO_Slag/RHO_Sinter;
//Check sintering and sinter appropriate amount of particulate layer
if(T_PartSint_ifc>T_Sinter);
Y_Part=R_Total*K_Particulate*(T_Sinter-T_Cool)/(T_Surface-T_Cool)-R_BASE*K_Particulate;
Delta_L_Sint=L_Part-Y_Part;
F_UDMI(f,t,2)=Y_Part;
F_UDMI(f,t,3)=L_Sint+Delta_L_Sint*RHO_Sinter/RHO_Particulate;
end_f_loop(f,t)
//Increment simulation time, print to screen and store current simulation time at UDM NO.5
thread_loop_f(t,d)
begin_f_loop(f,t)
cell_t c0;
Thread *t0;
c0=F_C0(f,t);
F_UDMI(f,t,5)+=TIMESTEP_SIZE;
/*C_UDMI(c0,t0,5)=F_UDMI(f,t,5);*/
end_f_loop(f,t)
BW1211 is offline   Reply With Quote
Old   July 14, 2021, 16:35
pakk will become famous soon enough
Your UDF is big. Can you remove the parts that are not relevant for this problem?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   July 14, 2021, 20:59
WB
Thank you for your reply. The udf can compile well and the main problem is that I use UDMI(2,3,4) as the calculation variable for the subsequent slag layer conversion, and the value of UDMI3 is negative. I hope you can help to see if there is a problem between these F_UDMIs. Thanks a lot. The simplified udf looks like this:
F_AREA(A,f,t);
if(F_T(f,t)>T_Slag)
return(PATH_ABORT);
return(PATH_ABORT);
return(PATH_ABORT);
thread_loop_f(t,d)
begin_f_loop(f,t);
T_Surface=F_T(f,t);
cell_t c0;
Thread *t0;
c0=F_C0(f,t);
F_UDMI(f,t,3)+=Y_Sint;
F_UDMI(f,t,4)+=L_Slag+Delta_L_Melt*RHO_Slag/RHO_Sinter;
F_UDMI(f,t,2)+=Y_Part;
F_UDMI(f,t,3)+=L_Sint+Delta_L_Sint*RHO_Sinter/RHO_Particulate;
end_f_loop(f,t)
Old   July 15, 2021, 02:09
You change UDM3 in two places. Which one makes it negative?
The method for solving such problems is to make the code smaller, until you have the smallest code that gives the problem. Your code stoll sets UDM 0,1 and 2, which are irrelevant to the problem. Simplify it...
And your code is not complete, T_sinter and RHO_sinter are undefined.
Old   July 15, 2021, 02:42
WB
Thank you for your valuable reply. UDM3 is indeed used twice and this may be the problem. UDM3 in DEFINE_DPM_BC represents the thickness of the ash deposition, the value of each layer The thickness is not fixed. In DEFINE_DPM_INJECTION_INIT, UDM3 is also used as a variable to calculate the thickness of sinter layer. The particulate layer can transform into sinter layer and the sinter layer can also transform into the slag layer.
I think there was an error when the different thickness was converted to each other. T_sinter and RHO_Sinter are defined as global variables,UDM0,1,2 are necessary to characterize the deposition characteristics.
Thank you very much for your patience and valuable suggestions, I wish you a happy life.
Old   July 15, 2021, 05:16
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in DEFINE_DPM_INJECTION_INIT you are using
but I don't see where F_UDMI(f,t,2), .... are defined
so L_Part .... may have random values from the very beginning.
that could be the reason of your problem
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 15, 2021, 05:27
WB
Thank for your reply. Sorry for the unclear statement, but F_UDMI(f,t,2)...are defined in DEFINE_DPM_BC as below:
if(F_T(f,t)>T_Slag)
return(PATH_ABORT);
return(PATH_ABORT);
return(PATH_ABORT);
Old   July 15, 2021, 05:59
Alexander
how could you know that DEFINE_DPM_BC is executed before DEFINE_DPM_INJECTION_INIT
I'm not sure here, but anyway, for this expression
you need previous value for summation, isn't it?
and previous value could be random
you may try to define explicitly values for
for very first time step
leeray1983 and Wang Cong NEU like this.
best regards
Old   July 15, 2021, 06:09
WB
Thank you for your valuable suggestion, I will have a try.
Old   July 15, 2021, 11:10
Then investigate!
Remove one, do you still get negative results? Make the problem smaller, until it's just a few lines!
Old   July 15, 2021, 20:47
WB
Then investigate!
Thank you very much. I will debug the udf code according to your suggestion.
Vawt simulation using udf LeftCoefficient Fluent UDF and Scheme Programming 0 February 27, 2017 14:25
UDF please Help HAWT (rotor simulation) Athmane Fluent UDF and Scheme Programming 0 April 5, 2014 05:55
Error on initialisation simulation after implemening UDF 0906536m Fluent UDF and Scheme Programming 0 January 10, 2014 06:21
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 05:30
UDF to change Rotation Speed in a MRF simulation Mike FLUENT 3 September 27, 2011 07:46
