UDF generation for pulsatile flow from sinusoidal wave
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   July 13, 2021, 08:21
Default UDF generation for pulsatile flow from sinusoidal wave
HARIREDDY
harry93 is on a distinguished road
Hello CFD wizards,
I am working on patient specific AVF Geometry, and I want to use the sinusoidal wave (Inlet mass flow rate) for pulsatile blood flow as inlet boundary condition, which is attached to this thread for reference. How do I create the UDF from this wave ?
Thank you
Regards
Hari
harry93 is offline   Reply With Quote
Old   July 13, 2021, 13:28
pakk will become famous soon enough
Do you have an equation for this pulse?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   July 13, 2021, 13:53
HARIREDDY
No sir, I have only that waveform figure. Please let me know, how can I proceed further from this waveform to create a UDF
Thank you
Old   July 14, 2021, 00:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
depends on how long your simulation will be :
1. you may use transient profile
Inlet Speed
https://www.ozeninc.com/tech-tip-flu...text-file-udf/
2. in case you are going to have long simulation you may try to use UDF:
a. divide your graph to some parts and extract equations for each
b. read your graph as a table and interpolate data between points
harry93 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   July 14, 2021, 03:28
HARIREDDY
Hello sir,
Thanks for your inputs. I've tried the 1st method i.e. to create the .txt file with X and Y variables. However, I would like to try using UDF rather than .txt file. Can you elaborate the points 2a and 2b ?
Thank you
blood flow, fluent - udf, pulsatile flow, udf code
UDF profile for a fluid flow through a valve elia.p Fluent UDF and Scheme Programming 0 May 2, 2017 06:52
volume flow rate for outlet boundry condition and dfine udf for it raminostadi FLUENT 0 December 24, 2016 02:52
UDF profile based on function of flow time ERROR! Ash Kot Fluent UDF and Scheme Programming 1 September 2, 2016 10:35
IHFOAM - Wave generation with moving boundaries Phicau OpenFOAM Verification & Validation 0 May 18, 2015 05:53
Wave generation, wave height reduces as it progresses haku88 STAR-CCM+ 1 August 6, 2013 20:32
