June 10, 2021, 05:30 |
Understanding of contact detection UDF
Rep Power: 6 |
Hello, everyone:
I am now using ‘contact detection’ function to keep a distance between two faces(one is stationary and the other is moving), some part of the UDF for contact detection is a little hard for me to understand since some macros cannot be found in UDF manual, so I am here asking for help to figure the whole things out. UDF code and my personal understanding of it have been presented in Figure 1 and Figure 2. Any advice will be appreciated, please help me understand those macros and share your point on the UDF code and my corresponding comments, thanks a lot! Regards, Silence UDF macros which cannot be found in UDF manual: 1.What is ‘Objp’? (Part 1, line 6) 2. Loop(o, contacts) (Par2 line 33) Loop the elements which pointer 'o' points to in contacts? 3.face = O_F(o) (Par2 line 35) 4.thread = O_F_THREAD(o) (Par2 line 36) 5.REAL_MIN (Par3 line 79) 6. SDOF_Get_Motion(dt, vel0, omega0, theta0) (Par4 line 113) Get the motion property of the structure which thread dt points to, velocity(vel0), revolution speed(omega0) and degree produced by revolution(theta0), am I right? 7. SDOF_Overwrite_Motion(ndt, vel1, omega1, theta1) (Par5 line 144) Overwrite the motion property of thread ‘ndt’, the new property of motion is: velocity_new = vel1, revolution speed_new = omega1 and degree_new = theta1, am I right? Logic problem 1./* 'Fetch current thread ID'---UDF manual, */, what does 'current thread' mean? (part 2, line 29), 2.tid = THREAD_ID(DT_THREAD(dt)), 'dt' was not defined in previous statement, why it can be used here? (part 2, line 30) 3.nid = -1; what is nid? why nid = -1? (part 2, line 31) 4.n_faces++, Obtain the total number of faces on face ‘nid’? (part 2, line 56) 5. N3V_S(xc, /=, n_faces), Is this operation to obtain the centroid of whole face? if so, is it an axiom? (part, line 81) 6. ndt = THREAD_DT(thread), convert thread to dynamic thread, thread is the pointer of face ‘nid’, why do this operation? (part 4, line 110) 7./* Reflect velocity across the normal */ v1dotn0 = 2 * N3V_DOT(vel1, norm0); N3V_S(norm0, *=, v1dotn0); N3V_V(vel1, -=, norm0); why not just N3V_V(vel1, -=, 2*vel1), why obtain the final vel1 through normal vector? (part 5, line 139-142)? Figure 1a Figure 1b Figure 1c Figure 1d Figure 1e Code:
#include "udf.h" DEFINE_CONTACT(contact_props, dt, contacts) { /* Define variables */ Objp* o; /* What is Objp? */ face_t face; Thread* thread; Domain* domain = NULL; Dynamic_Thread* ndt = NULL; int tid, nid, n_faces; real v0dotn1, v1dotn0; real nc_mag, norm0_mag, norm1_mag; /* Define 3D vectors */ real N3V_VEC(vel_rel); real N3V_VEC(nc), N3V_VEC(nctmp); real N3V_VEC(xc), N3V_VEC(xctmp); real N3V_VEC(vel0), N3V_VEC(omega0), N3V_VEC(theta0), N3V_VEC(norm0); real N3V_VEC(vel1), N3V_VEC(omega1), N3V_VEC(theta1), N3V_VEC(norm1); /* Check accessibility of cell values of variable in UDF */ if (!Data_Valid_P()) { return; } /* Define a common contact point / plane */ N3V_S(nc, =, 0.0); N3V_S(xc, =, 0.0); /* 'Fetch current thread ID'---UDF manual, What does 'current thread' mean? */ tid = THREAD_ID(DT_THREAD(dt)); /* 'dt' was not defined in previous statement, why it can be used here? */ nid = -1; /* What is nid? why nid = -1??? */ n_faces = 0; loop(o, contacts) /* What does this macro mean? */ { face = O_F(o); /* What does this macro mean? */ thread = O_F_THREAD(o); /* What does this macro mean? */ /* Skip faces on current thread */ if (THREAD_ID(thread) == tid) { continue; } /* Note ID of the other thread for posterity */ if (nid == -1) { nid = THREAD_ID(thread); } /* Initialize to zero */ N3V_S(nctmp, =, 0.0); N3V_S(xctmp, =, 0.0); F_AREA(nctmp, face, thread); F_CENTROID(xctmp, face, thread); /* Negative sum because wall normals point out of the fluid domain */ N3V_V(nc, -=, nctmp); N3V_V(xc, +=, xctmp); n_faces++; /* Obtain the total number of faces on face nid? */ } /* Assign calculation task to node in case of some errors, such as division of zero */ # if RP_NODE { /* Reduce in parallel */ nid = PRF_GIHIGH1(nid); /* Return the maximum value of nid among all of the compute nodes, why do this operation? */ n_faces = PRF_GISUM1(n_faces); PRF_GRSUM3(nc[0], nc[1], nc[2]); PRF_GRSUM3(xc[0], xc[1], xc[2]); } # endif /* Propagate to host, sending data between host and node */ node_to_host_int_2(nid, n_faces); node_to_host_real_3(nc[0], nc[1], nc[2]); node_to_host_real_3(xc[0], xc[1], xc[2]); /* Obtain parameters for nid face: (1) unit normal vector; (2) face gravity center. */ if (n_faces > 0) { nc_mag = N3V_MAG(nc) + REAL_MIN; /* What is the 'REAL_MIN'? */ N3V_S(nc, /=, nc_mag); /* Normalization for nc */ N3V_S(xc, /=, n_faces); /* Is this operation to obtain the centroid of whole face? if so, is it an axiom? */ } else { return; } #if RP_HOST Message ( "\nContact:: tid: %d nid: %d n_faces: %d " "Point: (%f %f %f) Normal: (%f %f %f)", tid, nid, n_faces, xc[0], xc[1], xc[2], nc[0], nc[1], nc[2] ); #endif /* Fetch thread for opposite body */ domain = THREAD_DOMAIN(DT_THREAD(dt)); /* What does this macro mean? */ thread = Lookup_Thread(domain, nid); /* Check whether thread is null */ if (NULLP(thread)) { Message("\nWarning: No thread for nid: %d ", nid); return; } else { ndt = THREAD_DT(thread); /* Convert thread to dynamic thread, why do this operation? */ } /* Fetch body parameters */ SDOF_Get_Motion(dt, vel0, omega0, theta0); /* Compute difference vectors and normalize */ N3V_VV(norm0, =, xc, -, DT_CG(dt)); /* Centroid - center of gravity, why do this operation? */ norm0_mag = N3V_MAG(norm0) + REAL_MIN; N3V_S(norm0, /=, norm0_mag); if (NULLP(ndt)) { /* Stationary body / wall. Use contact normal */ N3V_V(norm1, =, nc); N3V_S(vel1, =, 0.0); N3V_V(vel_rel, =, vel0); /* Compute relative velocity */ } else { /* Fetch body parameters */ SDOF_Get_Motion(ndt, vel1, omega1, theta1); /* Compute relative velocity */ N3V_VV(vel_rel, =, vel0, -, vel1); N3V_VV(norm1, =, xc, -, DT_CG(ndt)); norm1_mag = N3V_MAG(norm1) + REAL_MIN; N3V_S(norm1, /=, norm1_mag); /* Check if velocity needs to be reversed */ if (N3V_DOT(vel_rel, nc) < 0.0) { /* Reflect velocity across the normal, why not just N3V_V(vel1, -=, 2*vel1)? */ v1dotn0 = 2 * N3V_DOT(vel1, norm0); N3V_S(norm0, *=, v1dotn0); N3V_V(vel1, -=, norm0); /* Override body velocity */ SDOF_Overwrite_Motion(ndt, vel1, omega1, theta1); } } /* Check if velocity needs to be reversed */ if (N3V_DOT(vel_rel, nc) < 0.0) { /* Reflect velocity across the normal */ v0dotn1 = 2 * N3V_DOT(vel0, norm1); N3V_S(norm1, *=, v0dotn1); N3V_V(vel0, -=, norm1); /* Override body velocity */ SDOF_Overwrite_Motion(dt, vel0, omega0, theta0); } #if RP_HOST Message ( "\ncontact_props: Updated :: vel0 = (%f %f %f) vel1 = (%f %f %f)", vel0[0], vel0[1], vel0[2], vel1[0], vel1[1], vel1[2] ); #endif } |
contact detection, udf code |
UDF for dynamic Contact Angle | Wolfgang.Black | FLOW-3D | 0 | May 26, 2020 16:20 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 07:12 |
UDF for Contact Angle | gandesk | Fluent UDF and Scheme Programming | 1 | November 1, 2010 10:00 |
shock detection in the Riemann problems(specially in the stationary contact problems) | smkhan | Main CFD Forum | 1 | July 10, 2010 09:24 |
UDF for dynamic contact angle | Aireen | FLUENT | 0 | August 11, 2006 12:08 |
