Update Pressure values for unsteady, multiphase, parallel - not updating properly
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   June 3, 2021, 05:04
Default Update Pressure values for unsteady, multiphase, parallel - not updating properly
Dhayananth
dhaya400 is on a distinguished road
I am working on a unsteady flow problem with multiphase mixture model and run the simulation in Parallel mode.
For my problem, I have written a udf to update the pressure value of face boundary at every time step using the mass flow of the previous time step.
#include"udf.h"
real Q12; /* current time step flow rate */
#define BCA_ID 63 /* domain id*/
DEFINE_EXECUTE_AT_END(flow_rate_bca)
#if !RP_HOST
Domain *d;
real m;
cell_t c;
Thread *t;
face_t f;
d = Get_Domain(1);
t= Lookup_Thread(d, BCA_ID);
/* loop to calculate mass flow rate at outlet */
begin_f_loop(f,t)
if (PRINCIPAL_FACE_P(f,t))
m += F_FLUX(f,t);
end_f_loop(f,t)
Q12 = m / 1060.0; /* convert mass flow rate to volume flow rate */
#if RP_NODE
/* Perform node synchronized actions here. Does nothing in Serial */
Q12 = PRF_GRSUM1(Q12);
#endif /* RP_NODE */
m = 0.0;
#endif /* !RP_HOST */
DEFINE_PROFILE(pressure_out_bca,t,i)
#if !RP_HOST
real Z = 5.1918E+07;
real C = 8.697E-10;
real R = 10.6080E+08;
real ts = CURRENT_TIMESTEP;
face_t f;
begin_f_loop(f,t)
if (CURRENT_TIME == 0)
F_UDMI(f,t,0) = 13332.2;
F_UDMI(f,t,1) = F_UDMI(f,t,0);
F_UDMI(f,t,2) = 1.22E-05;
/* F_UDMI(f,t,0) - previous time step pressure
F_UDMI(f,t,1) - current time step pressure
F_UDMI(f,t,2) - previous time step flow rate
Q12 - current time step flow rate
else
F_UDMI(f,t,3) = Q12;
F_UDMI(f,t,1) = ((F_UDMI(f,t,0)*R*C)+(F_UDMI(f,t,3)*R*ts)+(F_UDMI( f,t,3)*Z*ts)+(Z*R*C*F_UDMI(f,t,3))-(Z*R*C*F_UDMI(f,t,2))) / (ts +(R*C));
F_UDMI(f,t,0) = F_UDMI(f,t,1);
F_UDMI(f,t,2) = F_UDMI(f,t,3);
end_f_loop(f,t)
begin_f_loop(f,t)
F_PROFILE(f,t,i) = F_UDMI(f,t,1); /* Calculate pressure and apply to outlet*/
end_f_loop(f,t)
Question:
When I physically calculate the pressure values and check with pressure output files from simulation, it is not matching. Is there any error in the code which is causing this problem?
dhaya400 is offline   Reply With Quote
Old   June 3, 2021, 07:29
pakk will become famous soon enough
It could also be an error in your own calculation...
How big is the difference? Which values do you get, which values did you calculate? Which equation do you think you are using?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   June 3, 2021, 09:49
Dhayananth
Hi Pakk,
Thank you for your reply.
I am using the following equation to calculate the pressure values for the outlet.
P(n+1) = {[P(n)*R*C] + [Q(n+1)*R*ts] + [Q(n+1)*Z*ts] + [Z*R*C*Q(n+1)] - [Z*R*C*Q(n)]} / (ts +(R*C))
F_UDMI(f,t,0) corresponds to P(n)
F_UDMI(f,t,1) corresponds to P(n+1)
F_UDMI(f,t,2) corresponds to Q(n)
F_UDMI(f,t,3) corresponds to Q(n+1)
Initializing, Q(n) = 1.22E-05 , P(n) = 13332.4 for CURRENT_TIME = 0
Result from simulation:
Q (n) Q(n+1) P(n) P(n+1)
1.22E-05 3.266E-05 13332.2 133324.4
3.266E-05 8.902E-05 133324.4 10423.9
Result from physical calculation:
1.22E-05 3.266E-05 13332.2 14629.7
3.266E-05 8.902E-05 14629.7 18429.7
Old   June 3, 2021, 23:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may write to console each term of your equation using Message0("text"); macro
code seems to be correct.
the only thing I would do -> split time step definition with applying the value:
was
to be
real ts;
dhaya400 likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   June 4, 2021, 01:57
You update F_UDMI(f,t,1) before you update F_UDMI(f,t,0), which seems wrong. Does not explain your current problem, however.
Old   June 4, 2021, 08:36
Dhayananth
Hi Alexander and Pakk,
I have incorporated your suggestions and made few changes in the code for updating the previous time step values.
The following code is moved out of face loop and made separate face loop for the code.
Using Message command, I have checked the values of F_UDMI variables with physical calculation, the pressure values are matching. But if I check F_UDMI values with pressure values from the report files it is not matching. Why?
For example, F_UDMI = 16733 Pa, Pressure from report file = 16084 Pa
I want to update the pressure values for mixture domain only. But while printing the values, I come to know that the udf is updating for all the domains. So how to make the define profile macro to update mixture domain alone?
Revised code:
#include"udf.h"
#if !RP_HOST
Domain *d;
real m;
cell_t c;
Thread *t;
face_t f;
d = Get_Domain(1);
begin_f_loop(f,t)
m += F_FLUX(f,t);
end_f_loop(f,t)
#if RP_NODE
m = 0.0;
DEFINE_INIT(init_pressure_bca,d)
Thread *t1;
cell_t c;
t1 = Lookup_Thread(d,BCA_ID); // for BCA
real P = 13332.2;
thread_loop_c(t1, d)
begin_c_loop_all(c,t1)
C_P(c,t1) = P;
end_c_loop_all(c, t1)
#if RP_HOST
Message("BCA Pressure Initalised\n");
#endif
#if !RP_HOST
real C = 8.697E-10;
real ts;
face_t f;
begin_f_loop(f,t)
F_UDMI(f,t,3) = 1.22E-05;
F_UDMI(f,t,2) - prevoius time step flow rate
else
F_UDMI(f,t,3) = fabs (Q12);
end_f_loop(f,t)
begin_f_loop(f,t)
end_f_loop(f,t)
begin_f_loop(f,t)
end_f_loop(f,t)
Old   June 7, 2021, 02:43
Dhayananth
While searching for multiphase -Define profile macro, I cam across the below line from the udf manual:
In multiphase cases a DEFINE_PROFILE UDF may be called more than once (particularly if the profile is used in a mixture domain thread). If this needs to be avoided, then add the prefix MP_ to the UDF name. The function will then be called only once even if it is used for more than one profile.
What does this line covey? Can anyone explain with example?
I think.. if I got the answer to this question. I will solve the error in the above post.
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
