How to apply the same UDF on multiple zone IDs?
Like Tree3Likes
  • 2 Post By pakk
  • 1 Post By DIWAS
Old   May 1, 2021, 12:35
Default How to apply the same UDF on multiple zone IDs?
DIWAS BAJRACHARYA
DIWAS is on a distinguished road
I have applied a UDF for a single zone and it works fine. However, I want to apply the same UDF(define_on_demand) on multiple zone ID which are not adjacent to each other.
I searched the internet and manual and user guide and I could not find a answer, I am using Gambit for meshing and I defined the different zones as a single zone ID but the results were wrong. Also, I am thinking about copy pasting the portion of the code and replace variables along with a different zone ID for different zones and then hook the UDFs. What is the proper way?
int Zone_ID=9;
t=Lookup_Thread(d,Zone_ID)
DIWAS is offline   Reply With Quote
Old   May 1, 2021, 13:49
pakk will become famous soon enough
Make an array with your cell zone indices, and do a loop over these indices.
zlwdml3344 and DIWAS like this.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   May 3, 2021, 05:06
DIWAS BAJRACHARYA
Thankyou so much it worked fine.
pakk likes this.
define_on_demand macro, udf and programming
polyhedral cells destroy FLUENT 0 January 18, 2018 06:14
UDF Read Data File for Zone Motion N'Furious76 FLUENT 0 May 9, 2017 11:39
UDF chip-exec and multiple UDF mmkkeshavarzi Fluent UDF and Scheme Programming 3 February 16, 2016 07:25
Calling zone name, zone id and total pressure from Fluent scheme to UDF kuldip Fluent UDF and Scheme Programming 2 October 6, 2014 01:23
udf for multiple reaction alihosseini63 Fluent UDF and Scheme Programming 0 July 4, 2013 19:37
