March 24, 2021, 11:43 |
Solar calculator daily cycle update
Plamen Avramov
Hello everyone,
I am trying to do a long time simulation, after doing some serious approximations, using the Solar Load Model. I am doing thermal research for the SWGO (Southern Wide-field Gamma-ray Observatory) and I want to simulate a water tank for about a month (or more) in 15 minute time steps using the solar load and see if the water freezes. I already have some UDF for real data I have, but once I pass midnight Fluent starts asking me to fix the hour. Doing this with journal files is not a great solution for me as I already have user-defined values for the sun intensity, ambient temperature, heat coefficients, etc. Is there any way for fluent to do that on its own or even using some UDF? I found a TUI command that adjusts the solar calculator position: /define/models/radiation/solar-calculator 40.7 -74.1 1 0 0 -1 1 0 0 19 7 0 0 y 1 ;set your correct location, date, time and mesh orientation etc. Is there a way that I can call this TUI command from a UDF? I will call it near midnight passing the hour and date to the next day. Using ANSYS 19.2 Thank you in advance Best Regards Plamen |
March 28, 2021, 23:46 |
Alexander
Rep Power: 34 |
you may try to use:
CX_Interpret_String(ti-menu-load-string (format #f "/define/models/radiation/solar-calculator 40.7 -74.1 1 0 0 -1 1 0 0 19 7 0 0 y 1" )); under some condition scheme scrip will execute whatever you want
best regards ****************************** press LIKE if this message was helpful |
March 29, 2021, 06:52 |
Plamen Avramov
Thank you a lot for your answer.
I managed to go around this by using a journal file with multiple commands (approx 1440 lines for a year to be precise). I used the define solar calculator and then set up the time step, number of time steps and iterations, after doing them, the journal file keeps reading the next lines without stopping and so on for every day of the year. NOTE: In order to be able to reset the time flow and back to 0 hours, the command (rpsetvar 'flow-time 0); is needed from the second day onwards. I hope this is useful for someone in the future, there is small amount of information about it. ; /define/models/radiation/solar-calculator -23.017 -67.753 -4 1 0 0 0 0 1 1 1 0 10 y 1 ; /solve/set/time-step 900 ; /solve dt 96 30 ; ; /define/models/radiation/solar-calculator -23.017 -67.753 -4 1 0 0 0 0 1 2 1 0 10 y 1 ; (rpsetvar 'flow-time 0); /solve dt 96 30 ; ; /define/models/radiation/solar-calculator -23.017 -67.753 -4 1 0 0 0 0 1 3 1 0 10 y 1 ; (rpsetvar 'flow-time 0); /solve dt 96 30 ; ; Best Regards Plamen |
June 24, 2021, 07:55 |
#4 | |
I'm running into a similar issue and I was wondering if you could give a little more detail on how you solved this as I'm fairly new to Fluent so don't fully understand everything you are talking about. Do I need to set up a file with these commands? and how is that read into Fluent? Sorry to be a bother. Cheers |
June 25, 2021, 01:52 |
Alexander
Rep Power: 34 |
usually you will run code above using journal file.
journal file is any text file with list of directives for fluent to run it use fluent interface: file-> read-> journal
solar calculator, tui, udf |
Odd results with solar load | me3840 | OpenFOAM Running, Solving & CFD | 2 | January 11, 2022 06:07 |
Modelling solar and thermal radiation in CSP solar receiver | Gioacchino La Rochelle | CFX | 1 | November 15, 2018 08:52 |
Profile Update Interval in Process Cycle Time | oozcan | FLUENT | 0 | August 3, 2016 07:38 |
Ansys Analysis and Simulate Solar Panel | Johnny leow | FLUENT | 0 | November 25, 2015 19:21 |
Solar Calculator | Dorasemon | FLUENT | 1 | July 25, 2013 10:20 |
