UDF for Navier slip condition
Like Tree1Likes
  • 1 Post By polopol
Old   March 4, 2021, 10:56
Default UDF for Navier slip condition
polopol is on a distinguished road
hello
I'm looking for an UDF to implement the Navier slip condition on Fluent. I would like to enter the slip length at the top of the UDF.
For the moment I've been working with the following UDF and selected the functions in Specified Shear. Unfortunately changing the slip length changes nothing in the results.
I've been working on a Poiseuille flow at low Reynolds (laminar) to see if the results were correct.
#include "udf.h"
Velocity slip at wall boundaries
separate routines for every velocity coordinate
UDF can be interpreted
at least 2 user-defined memories (UDM) need to be allocated first!
// wall slip layer thickness [m]
#define DELTA 10.0e-6
// under-relaxation factor for tangential wall velocity
#define RELAX_CT 0.1
DEFINE_PROFILE(slip_velocity_x,f_thread,index)
face_t face;
cell_t cell;
Thread *c_thread;
real u, v;
real ct, cx;
real gamma;
int i;
begin_f_loop(face,f_thread) // for each face: get face-id and thread
cell=F_C0(face,f_thread); // get corresponding cell
c_thread=THREAD_T0(f_thread); // get cell thread
u = C_U(cell,c_thread); // F_U(face,f_thread); // get cell center velocity u
v = C_V(cell,c_thread); // F_V(face,f_thread); // get cell center velocity v
gamma = C_STRAIN_RATE_MAG(cell,c_thread); // get strain rate (equivalent to du/dn at wall)
ct = (1-RELAX_CT)*F_UDMI(face,f_thread,0)+RELAX_CT*DELTA*g amma; // calculate tangential velocity (with under-relaxation using previous calculation step)
F_UDMI(face,f_thread,0)=ct; //store in user-defined face memory (id=0) for next calculation
cx = ct*u/sqrt(u*u+v*v); // component of ct in x-direction
F_PROFILE(face,f_thread,index) = cx; // assign to profile
end_f_loop(face,f_thread)
DEFINE_PROFILE(slip_velocity_y,f_thread,index)
face_t face;
cell_t cell;
Thread *c_thread;
real u, v;
real ct, cy;
real gamma;
cell=F_C0(face,f_thread); // get cell
ct = (1-RELAX_CT)*F_UDMI(face,f_thread,1)+RELAX_CT*DELTA*g amma;
F_UDMI(face,f_thread,1)=ct;
cy = ct*v/sqrt(u*u+v*v);
F_PROFILE(face,f_thread,index) = cy;
Nitish the Beast likes this.
polopol is offline   Reply With Quote
Old   March 4, 2021, 11:24
pakk will become famous soon enough
You might have very good reasons to implement your own version, but I should mention it nevertheless : velocity slip is standard implemented in Fluent, you don't need a UDF, just enable low-pressure boundary slip.
I don't have an answer to the problem in your post.
pakk is offline   Reply With Quote
slip boundary condition in the VOF model Sinon Lee Fluent Multiphase 2 September 27, 2018 08:27
Implementing Partial slip condition for solid particles in Lagrangian solvers surajkvs OpenFOAM Pre-Processing 0 April 13, 2018 04:08
Reflective wall and non slip condition? Jaydi_21 Main CFD Forum 6 February 20, 2018 15:43
Fluent UDF for Micro Flow Face Slip Velocity daniel_george_carter Fluent UDF and Scheme Programming 0 May 12, 2013 06:39
UDF Boundary Condition Victor FLUENT 2 November 6, 2003 12:37
